The new 2014 LS J2023H
   / The new 2014 LS J2023H #41
This page shows the different cabs that they offer.
Google Translate
It looks like 1,000 euro converts to about $1,375 US dollars. Not sure we can use this as an accurate idea of what that cab would cost here since the price they show on the base machine (without FEL) converts to well over $19,000. :eek:
   / The new 2014 LS J2023H #42
will be looking at the ls j2023h friday, does anyone know if it can take a 4-in-1 bucket?
   / The new 2014 LS J2023H #43
Well, it could actually work out for you, the new models are coming out and you could end up with a tractor that you didn't expect. good luck. It is tough waiting though.
Thanks whispering Oaks. As of last night, I may have another prospective buyer. I hope so. It'll still put me behind the 8-ball for another 45 days or so, but I can be a very patient person when I need to be.
   / The new 2014 LS J2023H #44
As in, the skid steer bucket? I've been told no at this point. They don't want someone putting extra attachments on that the tractor wasn't designed for. It could make it tipsy if the load were up high and out front enough.
Made sense to me when I saw the difference between the J2023H (new one) with a G3033H sitting right next to it. The G3033H had the skid steer compatible bucket already on it.
   / The new 2014 LS J2023H #45
Do you happen to recall what the price difference was between those 2 machines? I'm all in on a J2023H - but I'm also curious how much more it would take to get into a G3033H.
   / The new 2014 LS J2023H #46
would the skidsteer 4-in-one bucket 54"(390 lbs) bucket from Everything attachments or would that be too heavy for the J2023H? thanks
   / The new 2014 LS J2023H #47
From a prior posting: As of this past weekend, I'm probably going to opt for the G3033H myself. I can get it with TLB, tiller, remote hydraulics, rotary mower, and AG tires for $25408.00 out the door and delivered - tires loaded too.
J2023/J2030H same setup was about $21775.00 with same options. The J2030H is $100.00 more than the J2023H, so big deal on that. The price I posted here if for the J2030H.
I'm thinking the J2030H was a bit over 12K with FEL alone. The G3033H was about $16,100K with FEL alone. Please don't hold me to those figures as I do not have my notes with quotes with me right now. But it is a ballpark figure that is about right IIRC.
It sounds like a big jump in the price that was quoted to me for the G3033H over the J2030H with the same options. REMEMBER, the J2030H has smaller implements and hence the lower prices. For example: 48" tiller verses a 72" tiller, 48" - 5 ft rotary cutter verses a 6 ft rotary cutter. And of course the tractor/FEL combination and the backhoe sizes are different too.
   / The new 2014 LS J2023H #48
I honestly cannot answer that question. I'm not an engineer and have no idea of what would and would not work. I would be careful in changing things out as you may void your 5 year warranty.
   / The new 2014 LS J2023H #49
Thanks for the info. It seems the 2023 is everything I will need - but I want to make sure it's going to be everything I need for the long haul.
   / The new 2014 LS J2023H #50
My dealer was $12,200 for a 2023 with loader and $15,200 for a 3033 hydro with loader.
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
