345 noisy PTO
/ 345 noisy PTO #1
mikgran
SW Maine
1976 Bolens H14, 1970 110H, 1968 112H, 1977 210, 2001 345
Hi guys-
The PTO is noisy on my 345. It sounds like a dry bearing. It makes the same sound whether idling or with the PTO engaged. Is this repairable, or is the PTO on it`s way out?
/ 345 noisy PTO #2
If it's a bearing, they are replaceable. You obviously need to remove the clutch and then press out two bearings. Your local bearing house can match them up to new replacements and then you can press them back in --- if you can do this yourself, you can save a lot --- if you need to farm this out, then you're probably close to the cost of just buying a new clutch.
/ 345 noisy PTO
Thank you, Bruce.
I`ll try removing it and inspect the bearings. I`ll check NAPA to see if they stock the same basic bearing.
/ 345 noisy PTO
I should probably check the drive belt idler also. It almost sounds like the noise may be coming from that rather than the PTO. I`ll remove the tension from the drive belt and inspect.
I read another thread where the JD tech told the owner that they can be noisy and last years, so just drive it and replace it when it goes bad. I just acquired this tractor and do not know how long it`s been doing it.
/ 345 noisy PTO #5
If it still makes the noise when the pto is on and the blades are spinning it's not your pto clutch bearings. That bearing only rotates when the clutch is off when the clutch is on the whole bearing rotates with the shaft.
/ 345 noisy PTO
Thanks, YF440.
The noise is the same whether the PTO is engaged or not. It sounds the same as a tired deck spindle bearing. This is why I`m hoping it may be an idler pulley.
I have not tried the deck out, as it had a plow on the front at time of purchase. I need to go to my dealer tomorrow and pick up a draft plate. One didn`t come with the tractor. It may be called something different on these, but it`s the piece that is attaches the front of the deck to the frame. On the older tractors it`s a draft plate.
/ 345 noisy PTO #7
It probably is the idler pulleys for the traction belt it runs all the time on a 345. Yes the front piece is called a Draft link on the newer tractors.
/ 345 noisy PTO
Thanks, YF440.
I was at my local dealer today and picked up the new draft link, as well as a secondary (deck) belt. Parts for for the link assembly came to about $68.
They also echoed your opinion regarding the noise. This weekend I'll remove the belt tension and figure out which idler is failing.
/ 345 noisy PTO
Yellowfever440- You were correct. The idler pulley beside the PTO was noisy. I also found that the drive belt was cracked with a chunk missing, so I replaced both at the same time.
Also bought a new draft link from the dealer. Link with all the parts was about $70. Now ready for mowing season.
Thanks for your input.
2004 Chevrolet 1500 Silverado Truck (A63116)
2004 Chevrolet...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
Bushwhacker ST120 Offset Batwing Cutter (A64047)
Bushwhacker ST120...
JCT Brush Cutter (A64047)
JCT Brush Cutter...
60� Tine Rake (A64047)
60� Tine Rake...
