MF 231 glo-plug location/replacing
   / MF 231 glo-plug location/replacing #1
haycutter52
Member
Al
JD 5055E
Hi all
Where do I find the glo-plug on my 231 MF and is it easy to replace or test?
thanks
Haycutter
   / MF 231 glo-plug location/replacing #2
Hi all
thanks
Haycutter
I don't believe any of the Perkins AD3.152 engines had glow plugs. I could be wrong on the later models like your MF231, but my two MF245s do not have glow plugs.
Edit: I am seeing a Thermostart plug that MF231 may be equipped with. See attached, should be on the intake
Thanks TomSeller,
Where is the intake on this tractor?(I'm no mechanic)I mean if I remove something I can put it back. I just have to know where it is.
thanks
Haycutter
   / MF 231 glo-plug location/replacing #4
Thanks TomSeller,
thanks
Haycutter
This is not your exact engine, but the intake manifold is the lighter grey part towards the top. This is where the air comes into the engine and the Thermostart should heat this air. The thermostart should be to the left on the picture. This picture is of the right (passenger side).
   / MF 231 glo-plug location/replacing #5
This is for the MF 231..... NOT the MF 231S....
Look at where the exhaust muffler hooks to on the engine. The metal piece between the muffler and the engine is the manifold.
The 231 has a "Thermostart" for cold weather. Had to use mine a few times this year.
Turn the key all the way to the right but don't spin the starter over. You'll have to hold the key in that position because it's spring loaded and will just return to the 'on' position if u let go.
While you're holding the key in the position mentioned above, you should see a little smoke come out a tiny hole in the manifold after about 30 seconds to a minute. This lets you know that the thermostart is working. You may have to do this several times, but make sure you have the throttle wide open while trying to start the engine. I find this makes it much easier/faster to start. But when the tractor starts, immediately return the throttle back to idle so the engine can warm up.
When u see the smoke coming out the manifold, hold the key in position for another 20 seconds or so then try and start the engine. Keep repeating this process til the engine starts.
These Perkins engines are very strong and reliable, but are also known for "wanting to sleep in" when it's cold outside. Haha
Travis_R
Thanks for the information, I found it a few minutes ago and did as you suggested and on the second try it fired right up. The first time I had the throttle shut down and when I open it up some it fired right up.
Now I can set some hay out and get muddy...:(...:)....
Thanks again Travis_R.
Haycutter
   / MF 231 glo-plug location/replacing #7
Exhaust manifold? I have been under the understanding the thermastart burns fuel in the intake manifold to pre heat it.
   / MF 231 glo-plug location/replacing #8
I'm not exactly sure where the fuel is actually heated, but the SMOKE from activating the thermostart comes out a tiny hole in the manifold that the exhaust hooks to.
   / MF 231 glo-plug location/replacing #9
Travis_R Thanks for the information, I found it a few minutes ago and did as you suggested and on the second try it fired right up. The first time I had the throttle shut down and when I open it up some it fired right up. Now I can set some hay out and get muddy...:(...:).... Thanks again Travis_R. Haycutter
Happy to help and glad u got it goin. I also have both the owners manual and parts manual if you ever need info.
Thanks Travis_R for your help and also to everyone else who also shared their thoughts with me.
Haycutter
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
