Kubota l3800
/ Kubota l3800 #1
boyt
Hi I'm thinking of purchasing a Kubota l3800 has any one had problems and comment on the l3800 appreciate
/ Kubota l3800 #3
/ Kubota l3800 #4
Search button .
But I just bought a L3800hst Saturday and love it so far .
Sent from my iPhone 5 using TractorByNet
/ Kubota l3800 #6
I just bought a L3800 and love it. I compared it to the JD 3038E and it is in my opinion a much better tractor. Do the side by side comparison and you will see the difference.
/ Kubota l3800 #7
And the 3PH on mine is smooth. No jerking around.
/ Kubota l3800 #8
I have had an L3200 ( almost identical to L3800 albeit less HP)for 15 months now w/ zero issues. I stepped up in size from a B7610.
/ Kubota l3800 #11
Mine is an 09 L3400, 3800 is the same basic tractor with different bodywork and a few refinements. My hitch is jerky, but the rest of the tractor is really very good.
About 2 years in, the clutch started refusing to release, dealer split the tractor (under warranty) and found the input shaft splines rusty and sticking. Cleaned up and lubed them, no problems since then.
Good power and easy cold starting. Having the throttle pedal, brakes, AND diff lock pedal on the right side makes it hard to use brakes for steering on the gear drive models. Same with the hst version, has brakes and hst pedal on the same side.
Sean
/ Kubota l3800
What is the clutch for on the hst models
/ Kubota l3800 #14
Sean
Mine is a gear model and I've never had issues with the brake pedal, throttle & diff lock all on the same side. Actually every tractor I've had has been this way...
/ Kubota l3800 #15
Sean
Sean do you mean there isn't enough room on the right side to operate because of limited space, and the number of controls on that side?
You wouldn't be using the dif. lock and steering brakes at the same time, so that shouldn't be a problem in itself. I generally use the hand throttle if I use the steering brakes.
The HST models with the brakes on the right never made sense to me. Other than using both feet on the right side of the tractor, I don't see how you could use the steering brakes at all.
I had a New Holland HST with the brakes on the left. It took a little getting used to, but was a much better arrangement IMHO.
Bill
/ Kubota l3800 #16
Once I got used to the Kioti's DK's brakes on the left (took about 2 days).. it is an absolute joy to operate using brake steer on the ice. I could use the Kubota with the right brakes, by using the cruise control, but it was still awkward. But I can operate on my side sloping driveway to clean it off so easy now, just give her a little right or left "rudder" and I can hold a straight line now. :thumbsup:
/ Kubota l3800 #17
So far I have let to even use the brake on the HST .
/ Kubota l3800 #18
I don't like using the hand throttle for snow clearing, which is when I want to use the brakes to steer. About the only time I use the hand throttle is for mowing an open field.
Using the diff lock to get unstuck is another situation where I'd rather use the foot throttle for better control.
I've actually looked at what it would take to move the diff lock to the left side, not an easy project.
So, unless I grow a second right foot, which according to my wife I already have, it's a pain in the azz.
Sean
/ Kubota l3800 #20
So, unless I grow a second right foot, which according to my wife I already have, it's a pain in the azz.Sean
I try to only engage the differential lock w/o load, so the clutch would be in. A left side lock pedal wouldn't work for me, at least. How about a hand lever?
None of the tractors I grew up with had foot throttles, so using a hand throttle is no big deal for me.
I've never seen a gear drive tractor set up any different?
I don't think I have either. I have seen some with oddly placed hand throttles, like they don't expect you to use them.:confused2:
Red Cedar Glider Chair (A61569)
Red Cedar Glider...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
