Kubota vs Kioti, hydro vs gear trans.
   / Kubota vs Kioti, hydro vs gear trans. #21
Plowing is a power intensive operation. It is slow and takes a lot fuel. Gear transmissions are more efficient, and they produce less waste heat. Hydro transmissions are more likely to fail due to overheating.
For plowing a few or a dozen acres, no problem. Start talking about much more, and the extra power and efficiency of gears would be a must.
+1. Plus, it's great to be able to select the right gear, crank the throttle up, let out on the clutch and go. The advantage of the HST transmission (which I have and love) becomes a disadvantage and a distraction when you're plowing a field for 12 hours.
   / Kubota vs Kioti, hydro vs gear trans. #22
My concern about this is how a newbie buyer/operator deals with the decision making process choosing between hydro and gear transmissions. Matching the tractor to the tillage tool is a very important consideration, if these are properly matched overheating shouldn't be a problem. While a gear tractor is more efficient I don't see that as an issue for the typical small property owner. Both gear and hydro transmissions are very dependable and can both pull a plow all day without problems. How many days a year does a typical small acreage owner spend plowing compared to other tasks? I would think that this would be a minor use of a tractor for most people and the other tasks using the fel with direction changes in close quarters work is the norm.
In most cases buying a compact tractor as your first tractor I would recommend the hydro transmission. For larger properties most will have more than one tractor and a larger gear tractor in addition to the smaller hydro tractor can make a lot of sense. I am thinking about a new 100+ hp for the fall but will keep the smaller hydro tractor for the close quarters work I do.
   / Kubota vs Kioti, hydro vs gear trans. #23
The title pretty much sums up my question, I'm in the market for a 35-50hp w/fe loader tractor. I really no idea which way to go, and throwing in the transmission choice, I'm stuck. Is the hydro dependable, I know it's easier to manage/use. If this question has already been asked and answered, please redirect.
Back to the first post by the OP, like most people he is concerned about the hydro being dependable. I think it is as there are very few threads with transmission problems on any of the brands.
Looking at a small tractor with fel, I doubt he is planning on major use plowing all day every day.
   / Kubota vs Kioti, hydro vs gear trans. #24
Agreed, hydro's are super reliable, and offer the utmost in convenience. I would also say they are considerably safer to operate for beginning users. I was just answering the question of why gears are better for plowing, which they certainly are. That said I would agree that plowing is not why most people buy these kind of tractors, and not a huge concern. Also, I thought your gauge was a little off you asked, how many days a year most cut owners plow for. I think, not many, but also, how many days/year do big corn farmers plow/year. Also not many. Lots of plowing, and fuel consumption can happen in a small number if days. Everything you said is right on, though. Sorry to be a little nit picky.
   / Kubota vs Kioti, hydro vs gear trans. #25
   / Kubota vs Kioti, hydro vs gear trans. #26
I don't disagree with you at all. My point was just that, for those guys who DO intend to use their tractor to plow all day long, gear is a better choice. But I think you are absolutely correct that most COMPACT tractors are not used for that type of use.
Most of us who buy compact tractors need for them to be do-it-all tools. That's where the HST shines, and that's why I wanted (and got) an HST tranny on my tractor.
   / Kubota vs Kioti, hydro vs gear trans. #27
I do plow any, but still much prefer gear drive! :D
   / Kubota vs Kioti, hydro vs gear trans. #29
I have Both :D
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2020 FREIGHTLINER CASCADIA 125 SLEEPER (A54607)
2020 FREIGHTLINER...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
2022 PETERBILT 579 TANDEM AXLE SLEEPER (A54607)
2022 PETERBILT 579...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
