Tiller Need advice about Bush Hog Rotary Tiller RTC50G
   / Need advice about Bush Hog Rotary Tiller RTC50G #1
ivanshee
Ankeny, Iowa
Kubota BX25
My friend have a Kubota BX-1830D, but he do not sure if his tractor is powful enough to drive Bush Hog RTC50G.
Anyone use RTC50G on Kubota BX-1830D? Can Kubota BX-1830D drive it?
How does RTC50G handle brush/long grass/weeds?
How does RTC50G handle roots?
Thanks
   / Need advice about Bush Hog Rotary Tiller RTC50G #2
I would say no that it can't handle it very well at all. If your tilling easy ground shallow then it would do the job but trying to till deep will choke down the tractor. I've never used that combination however. Tillers till the soil they arn't used to clear brush or cut down weeds or grass. Weeds and grass usually just wrap around the tines and causes a big tough mess to get off the tines. Tillers can bounce over smaller roots but arn't designed to cut them. They can handle weed and grass roots well however provided you've mown the tops down so they don't wrap around the tines.
Thanks for your advice.
   / Need advice about Bush Hog Rotary Tiller RTC50G #4
That is a SubCompact tiller. At least that is what Bush Hog says on there web site.
You should be ok with it. You may have to go slow.
2014 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2019 Autocar ACX Xpeditor Garbage Truck (A55852)
2019 Autocar ACX...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
