Box Scraper Smoothing a Bumpy Pasture
   / Smoothing a Bumpy Pasture #31
   / Smoothing a Bumpy Pasture #32
Man, nice looking place. But i agree on one thing. youll hate having to mow all them acres every week. It sure gets old.
Personally, if it were me id spend the $$ fencing it off and just smooth out a nice area for house, shop and play area. Get goats or ??? to maintain the rest automatically (once you live there).
I used to mow the 10 acre area out front of my place to keep weeds down, etc. man that got old. Going round and round in circles. Years ago i fenced it off and throw the horses out there.
   / Smoothing a Bumpy Pasture #33
Since it was a soy bean field it had been worked previously. Get a local farmer to plow and disk it and start over. You can drag a chain harrow over it then and have a very fine smooth surface to grow grass. It may seed itself and if not plant seed in the early fall as that is the best time for grass seed planting. It will be cheaper and faster than hauling topsoil to fill in the rough spots and will give you a superior result from day 1.
I agree with Corl. Since it already was a crop field, you don't need to bring in any topsoil. Just break the ground up (if you till it, it will move easily and you can use a box blade on it), re-plane it, seed it, roll it, and stand back. Tilling it would destroy most of the root systems, requiring you reseed it.
You could plow and disc it. I don't think just disking it would level it very well though.
   / Smoothing a Bumpy Pasture #34
A disc harrow is what is needed for sure, if you have low areas or dips use a box blade to even it up and then use drag harrow to smooth it out.
   / Smoothing a Bumpy Pasture #35
Could you disc and then use this from Tractor Supply to smooth everything out??
After the seed is down, could you flip this over and go over the seed again to get it in the ground?
   / Smoothing a Bumpy Pasture #36
Do you have any haying neighbors? Wouldn't hurt to leave it a pasture and plant some bermuda / orchard grass once you get it smoothed out. Just have a neighbor farmer cut and bale it for half of the yield and sell the rest on craigslist. Probably get 2 cuts / season where you're at. Also would make a great place for wildlife to be found and harvested during the appropriate season. Not practical if someone has to drive more than a few minutes to get to you. Just a thought. If you plan to do a garden, get a tiller and till it then hit it with a landscape rake a few times followed by a piece of chain-link fence with a couple used tires on it drug behind the tractor. Else, find the attachments you will use on CL and turn around and sell them once the work is complete.
   / Smoothing a Bumpy Pasture #37
Thanks for your excellent ideas Jenkinsph! Your property is AWESOME!!:) Where are you located? What type of grass did you use? What is a landplane?
Thanks for the kind words, I live in Ruidoso New Mexico at about 7000 ft elevation. I have Tall Fescue that is green about 9 months of the year. Here are some pictures of the landplanes and harrow I built to smooth out the erosion ditches and stump holes. Both are 8' wide and cost about $1150 to build both tools. The last three pictures are of customer projects that the landplane was used to smooth out.
   / Smoothing a Bumpy Pasture #38
Then shoot yourself in the head.
You gonna play tennis on it? You gonna play polo on it? You gonna make a baseball diamond on it? You gonna play soccer on it? How about croquet?
Are you gonna to anything but mow that dam grass?
Biggest waste of time and energy modern man has ever invented. Maintaining mown lawn to no good purpose.
Yes, the waste is obvious.
But it shows to everyone that you do not need the productivity of that land to provide income or food to yourself and family.
(the real truth behind lawns)
   / Smoothing a Bumpy Pasture #39
JENKINSPH: Beautiful Hacienda, beautiful land.
   / Smoothing a Bumpy Pasture #40
Thanks Jeff,
I enjoy this type of work. It helps to be able to see the result of my work at the end of the day. Having been in the plumbing and mechanical business for 30 years it is a nice change. When working on plumbing no one ever says "look how pretty those pipes are". I may not make as much money now but I enjoy my work immensely.
resallen and CalG,
Hope both of you can find something that makes you happy.
2015 Chevrolet Silverado 3500 Knapheide Service Truck (A55973)
2015 Chevrolet...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A58018)
2006 INTERNATIONAL...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
