Should I buy a new G-Series Toolcat 5600? Please help!
   / Should I buy a new G-Series Toolcat 5600? Please help! #11
Frank,
I have a Ventrac 4200 (with a cab, rough cut mower and snow blower), a Toolcat F series (snow blower and angle broom, stump grinder, mower, and tree shear), a Kubota RTV 1100, and a Kubota M5040 (Cab, plow, FEL, mower, grapple).
For transporting stuff and going to the mailbox the RTV is clearly the most convenient - easy to drive, never get's stuck (has a manual differential lock), and goes 25 MPH.
For heavy snow, the tractor with the plow is fastest. The only issue is when we get a lot of snow, the snow banks become too high to pile snow to the side. But it never gets stuck and at times I had to use it to pull out the Ventrac and the Tollcat when they were stuck (Toolcat three times this winter, and Ventrac once)
The Toolcat with the snow blower is awesome. The only issue is that if you get one wheel off the road, it spins and the machine is stuck. Since you are getting a G-series, the HTC is a must and it may solve the issue as I have never had problems when all four wheels were on the road (admittedly I have no steep hills). But going to the mailbox in the Toolcat seems like an overkill and it only goes 18 MPH
The Ventrac is a very handy machine, very maneuverable and the snow blower is 5 feet so I can clear the narrow pass ways and close to the house. Again, the hydraulic drive is great but a problem when one wheel loses traction. Going to the mailbox is not ideal (not easy to switch into high gear and even then slow) and no loading bed.
The RTV is very useful, but no snow blower (there may be a way of powering one) but plows are readily available.
The bottom line is that if you are getting only one machine, then get the Toolcat but insist of getting the HTC and possibly a winch if you get stuck to pull pout the Toolcat (or use your Kubota, but the Toolcat is very heavy and it was a job to pull it out of the ditch even with my M5040)
Hope this helps.
TL
best -
   / Should I buy a new G-Series Toolcat 5600? Please help! #12
I have an '09 "D" series Toolcat. I plow and snow blow steep inclines (12% grades both paved and gravel) along with highly crowned and off camber driveways. I'm not sure which traction system mine has but it works very well. Once you get used to to you particular properties's peculiarities you drive it accordingly and you stay out of trouble. It is not a tracked tank but it will do many things very well. Mine does have better snow traction in 2 wheel steer but obviously better maneuverability in 4WS, so I switch between the two as conditions and needs dictate. The 72 inch snow blower makes quick time of a lot of snow and eats through anything I throw at it. The 84 inch snow blade cleans the drives in one fell swoop. I have 29 inch tires on mine and when the steep drives are very icy a few hundred pounds of weight (sand bags) in the back to balance out the weight of the 800 lb SB help noticeably. I have chains for it but have never needed to install them. Recently, Bobcat came out with the 3650. You may want to consider looking at it to see if it meets your needs as well.
DEWFPO
Thanks to everyone who's replied. TL & DEWFPO, thanks for providing your firsthand experience with your TC's. That's exactly what I was hoping for.
I'd prefer just to have one machine to handle all of my needs. That's why I settled on the TC. Thanks for confirming that for me TL.
DEWFPO - I've looked at and driven a 3650. It's a great little vehicle, and on paper, it should do everything on my list. I'm just worried that it won't hold up over the years. The Bobcat 3650 is a sister vehicle to the Polaris Brutus HD PTO. I own a Polaris Ranger 800, and the 3650/Brutus are built on the same frame as my Ranger. The coils on the suspension are beefier on the 3650/Brutus, but the rest of the suspension is the same. This is all to say that I'm not satisfied that my Ranger, which I use as a toy, could handle 10 years as a work vehicle.
I think I'll try to find some reviews on the 3650 before I pull the trigger on the TC. Since production of the 3650/Brutus only began in 2013, there's not much information out there with owner's feedback. The OTD price I have on a 3650 with a snowblower & blade is 28k. It's very tempting...
Thanks again for your responses!
   / Should I buy a new G-Series Toolcat 5600? Please help! #14
I spent part of the day comparing my D to a demo G I have for the weekend. We still have a couple feet of snow and I was able to compare traction capabilities. After years of running my D with chains on the front tires I bought 4 studded snows and rims this year for a major confidence boost.
Yesterday I would get G stuck then turn on traction control and generally, but not always be able to keep climbing. Then I would try my D in same spot and be able to go same or further with it. The thinner snow tires do not float on snow like skid steer tires and it make's me wonder why Bobcat has not realized this and offer Toolcat with a thinner tire option?
The G has a slightly better ride,power attach, traction control ,extra controls on joystick and new motor is a little bit quieter than D. The ride quality interested me because the shocks look the same? So I checked it out online and they are same parts number 668831? Either they have been updated or mine have degraded in quality of ride?
Have not made up my mind on new machine but can say if you do buy a toolcat and have any trouble with traction during the winter do not hesitate to buy a set of studded snows with trailer rims.
My wife made 3 movies on iphone but when uploaded to site it said they were invalid?
Thank you very much for the response. I wish one of the dealers around me had a G-Series that I could demo. Based on your report, it sounds like I'd be happy with a G as long as it had traction control and I go into the purchase knowing that I may have to add studded snow tires. Good luck with your decision on upgrading to a G TC.
Frank
   / Should I buy a new G-Series Toolcat 5600? Please help! #16
Frank, I can't help with traction in the snow, never driven in any, but it will haul the trash! :D
   / Should I buy a new G-Series Toolcat 5600? Please help! #17
No one has commented on your inquiry as to how well it handles sand/mud. With the weight of the Toolcat it certainly won't be as good as a side-by-side and if you got it bottomed out, you're looking for a tow but if you use common sense and stay where you have traction but are making some ruts -- will it handle it, churn it's way through or give up??? Comments please.
   / Should I buy a new G-Series Toolcat 5600? Please help! #18
The only time I get stuck is if one wheel loses traction and spins while the other are stationary. The HTC should help though. (I am seriously considering upgrading to a G for that reason - just waiting for people to report their experience with HTC.) But I would give serious consideration to the 29 inch tiers to increase ground clearance.
TL
   / Should I buy a new G-Series Toolcat 5600? Please help! #19
I don't have much experience in the snow, but my 5600 has been a lifesaver here around the farm. Mine is a late A or early B model, I got it late 2004. I have a little over 3000 hrs on it. I mow with it, have a set of forks, and a bucket. It does what I need it for. The only drawback for me is the lift height, I wish it was more. I would love to have a new one, but I can't swing $50,000+ right now.
   / Should I buy a new G-Series Toolcat 5600? Please help! #20
Hello all!
I just became a member of this forum recently, but I've read most of the posts regarding the Toolcat 5600/5610 over the last several months. I truly believe that the TC is the best solution for my needs, but I've become more and more concerned about the TC's traction ability in snow and on moderate grades. --------------------
As far as blowing leaves go, this would be done in dry weather but for much of the work the TC would be running on my lawn. There is an area that has a relatively steep incline and I'm wondering what type of problem I'd have there.
No problem! The hanging chain shows true vertical.
I'm looking at ordering the TC in the next week. I've already been informed by my dealer that if I order one now it'll be built in AUGUST!! There sure must be a demand for these things... I've checked every box on the order from with the exception of the 29" turf tires.
Please let me know what your thoughts are. Thanks!
Frank
Did you order it?
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
FORREST RIVER CHEROKEE CAMPER (A55745)
FORREST RIVER...
Mobile toilet with shower (A53424)
Mobile toilet with...
New 4-10-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-10-16.5...
