Rake Found these used rakes on Craigslist - whacha think?
   / Found these used rakes on Craigslist - whacha think? #31
The guy is stating its a Woods rake.
Does it really look like a Woods rake to anybody?
Reading a lot of reviews on the TSC rakes and there seems to be a big quality issue. Lots of people posting reviews of bending these rakes rather quickly.
I always though the angle iron styles were cheep, but I'm hearing differently and can not be sure this is the angle iron style without more pics
I bought one that looks pretty much identical for $150 locally. It works okay, but nothing special....and it's only 6', so I'm planning to get a 7-8' EA XTreme Ver 3 soon.
This one needs some paint, but is much more stout....if it has a good cutting edge, you'd be set. They'd probably take $350, and you could check on the rake in the background as well.
6' 3pt heavy duty scraper blade
How'd you find that. I'm searching Craigslist every day :D
I'll be contacting them. Wonder if that Landscape Rake is for sale too
no, thanks!
   / Found these used rakes on Craigslist - whacha think? #37
Just play around with the search terms....back blade, scrape blade, tractor blade, etc. You can also search by entire state using third-party websites like: Search Craigslist by state and More.
If it helps any, I ran a 6' blade, and 6' rake like the ones in the CL ad I linked with my 8N, which had an 800lb 3pt limit, and it was fine. My new EA Xtreme 8' blade only weighs 800lbs, and it's a beast in comparison, so that blade would be much lighter. I was mostly moving snow with the 8N, but it also moved dirt fine.
   / Found these used rakes on Craigslist - whacha think? #38
   / Found these used rakes on Craigslist - whacha think? #39
Nice find. A bargain.
Yeah....couldn't really go wrong with that one. I bought the 5' cutter next to it for $350 as well. It had blue under the yellow, so I think it was a King Kutter. Not a bad haul for $500!
Re: Found these used rakes/blades on Craigslist - whacha think?
I found these last night thanks the Gittyup's suggestion.
So this is where I'm at. I only need to maintain a small section of road/parking lot/driveway (red area) That's my house and lot. Up until December, I did it with a 4' tow behind York Rake on a garden tractor.
I might be able to pick up some work 1-2 times a year maintaining the yellow section and if I'm lucky, I might get the blue section to
Each color is owned by different people and right now, neither of them maintain the road. Last year the blue section hired a landscaper to fix potholes at a cost of $2,000
That consisted of filling them in with gravel and some grading with a bulldozer...it didn't work naturally.
While this would only be "side work" for me. I would not mind picking up a little money to play on my tractor, but I understand that my tractor is a "little small" for this, but I know it can be done as long as I don't rush it.
Once in a while, I'll need to repair my lawn from vehicle traffic putting in boats and taking them out, but the tractor is used mostly to mow the lawn and dethatch as well as haul weeds we rake out of the lake.
I've got a Kioti CS2410
24 hp, Class 1 3PH, 48" wide, 1485 lbs w/turf tires.
Found these
60" Woods LRC60 w/casters (really a Woods this time, not like the Woods that was a King Kutter before :/)
Asking $500
60" Woods LB3 Scraper Blade
Asking $300
60" Sundown Box Scraper
$650
So what do you Pros think of the equipment above?
Am I better off with a Box Scraper over a Scraper/Rear Blade? Which one has more uses? I'll be doing a bit of lawn repair this Spring leveling out topsoil and regrading the driveway to get rid of some low spots.
TANK MANIFOLD (A55745)
KUBOTA M7-132 (A53084)
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
