Are some of the Kioti precautions BS?
   / Are some of the Kioti precautions BS? #1
DroppedAxle
Atlantic seaboard
2007 Kioti CK20S HST with KB2465 backhoe
As a new owner of a Kioti (and my first tractor), I'm reading the owner's manual cover to cover (it's raining here). Kioti tells me to never get off the tractor while it is running. But then how am I supposed to get into the BH seat? Also, if I'm letting it warm up for the suggested 20+ minutes in sub-zero temps, do I really need to stay on the tractor? Some precautions, like not starting the tractor while standing next to it, make much more sense...imho. What do you do?
   / Are some of the Kioti precautions BS? #2
Use your head. Common Sense
   / Are some of the Kioti precautions BS? #3
   / Are some of the Kioti precautions BS? #5
ya, its to protect their rears. The only time i personally would worry about leaving the seat with engine running is if there are kids around. they will mess up anything.
but you have to gain experience around the machine for your own comfort level.
   / Are some of the Kioti precautions BS? #6
On my Bobcat, if you set the parking brake you can get off the seat with the engine running. The one warning I do take more seriously is getting off the tractor with the PTO engaged. I have been known to do it ... but only if I'm not going anywhere near the back of the tractor and only if no one else is anywhere near. The PTO spinning can be dangerous.
Have fun and good luck.
MoKelly
   / Are some of the Kioti precautions BS? #7
MoKelly
That is one of the electrical differences between the Kioti and the Bobcat.. On the Kioti there is no seat switch. Only the range selector Neutral switch. The brake does not have to be set on the Kioti, the engine can be running, and you can get off. No Nanny switches, you are free to let it roll off, or smash yourself if you please. It is all up to you.
   / Are some of the Kioti precautions BS? #8
MoKelly
I don't observe all safety rules religiously but I do always wear my seat belt and always disengage the PTO when dismounting unless using the wood chipper. I cannot think of another reason why one would leave the PTO on (well maybe running a post hole digger??)
   / Are some of the Kioti precautions BS? #9
I have been known to be lazy and leave the PTO running when I am mowing if I run across something in front of me that I have to get off the tractor and move out of the way (e.g., branches). That is what I was referring too in my situation.
MoKelly
   / Are some of the Kioti precautions BS? #10
MoKelly
Got it. I almost always have my grapple mounted when mowing and as I am lazy, I use it to move anything I don't want to mow over.
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Fast 9613N 1300 Gallon Sprayer (A57148)
Fast 9613N 1300...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
