Forks Budget Pallet Forks by Paynesforks
   / Budget Pallet Forks by Paynesforks #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Any of you guys in the USA any experience of owning and using Budget Clamp On Tractor Bucket Forks Pallet by Paynesforks ?
As usual impossible to get anything like this in the UK so may import.
Seem really cheap but I am not going to be lifting anything really heavy (my loader states 200kg max)
They are on Ebay at Budget Clamp On Tractor Bucket Forks Pallet Kubota John Deere by Paynesforks | eBay
Thanks in advance
   / Budget Pallet Forks by Paynesforks #2
No, sorry I have no experience with these but seems to me you can make some from metal in the scrap pile maybe even a little sturdier depending on what rating and dimension of steel you use. Get all the materials you need and layout the design on paper and weld it up. Even if you have to buy the steel and clamps and pay for welding it should be cheaper and sturdier than these. Good luck..... KW
   / Budget Pallet Forks by Paynesforks #3
I don't want to be negative but clamp on forks are just what they say, they clamp on. When you drive into an object to pick it up they slide around, no matter how tight you get them. I had a set of them and i scraped them because of that reason. Also the fork being set on the end of your bucket means the load is farther away from the pivot pins on your bucket thus decreasing your lift capacity. They are cheaply priced but with cheap you get other issues which just are not worth the hassle. Hope this helps . . . .John
   / Budget Pallet Forks by Paynesforks #4
Agree 100% with all of the above. Add to that the fact that you can't see through your bucket to be able to hit your target properly. I had a set. Got them simply because I could have them delivered quickly to me when I had a truckload of stuff being delivered to the house soon after. As soon as I could afford a set of real forks, the Payne's went on Craigslist and were gone soon after.
   / Budget Pallet Forks by Paynesforks #5
I posted this video a while ago on another thread. Here it is again. Hope it helps.
Thanks to you all for your replies/advice. 55 years tells me you generally get what you pay for and as someone else said to me recently buy cheap buy twice!!
Great thank you could you tell me what size the chain and load binders are?
   / Budget Pallet Forks by Paynesforks #8
I sent you a private message in response to your message. I'm not getting auto notices from TBN even though I am subscribed.
Very many thanks for the information on the sizes will see what I can get over here
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
JCB 2145 (A47477)
JCB 2145 (A47477)
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
