skidding on black ice
/ skidding on black ice #61
ABS does not stop faster, it simply allows the driver to maintain control during a panic stop. In fact non ABS brakes will stop faster in snow and gravel due to the snow/gravel piling up in front of the skidding tyres.
The cousins in the alps turn off ABS in snow... especially on the gravel roads up to the farms away from where the pavement ends... every car over there with ABS has a switch to turn it off.
/ skidding on black ice #62
I have a car with traction control switch that stops the brakes from being activated due to wheel slippage. So if you are in deep snow, sand or other poor traction conditions, it won't activate the individual brakes when the vehicle senses a slippage. Works pretty well and the feel would be more familiar to those of us with older all wheel, 4 wheel drives.
/ skidding on black ice #63
To the mason dixon poster, yes we get black ice here, happens every fall and spring rarely in the middle of winter as there is so much residual salt on the road. The patches of it are often intermittent though so you can coast over them. Probably 10 days of driving with it per year locally. Coastal areas up here get it more often. You can tell quickly in most vehicles as the steering feel changes ever so slightly, feels like a little power steering boost.
We also get a lot of freezing rain, maybe 10-15 days of driving with that too. Road looks wet but will become coated in ice under the water.
If you want to get anywhere you drive on it and learn to deal. The worst is the heavy freezing rain. It comes on quite suddenly. The salt trucks can't melt it fast enough and it completely coats all surfaces. You end up having to drive on the snowbanks if there is any turns or hills. 4wd and studs let you get around a bit going slow but steep hills are just a slide. For short distances v-block chains work well.
I remember I got stuck at the top of an 8% grade a few years ago with 4wd and studded snows. There was about a half dozen cars off in snowbanks on the hill.
The people that had tried to get out of their stuck cars kept falling down and sliding down the hill.
/ skidding on black ice #64
Black ice or snow I want ABS, traction control, stability control and limited slip differential all working. I also am not going to be traveling in excess of 40 MPH in snow and much less on ice. Once a vehicle starts sliding on ice you are along for the ride. Four wheel drive or six wheel makes little difference, you are not going to move on ice. A good example of people trying to drive on ice was recently put on display for all to see in Atlanta Georgia.
/ skidding on black ice #65
It makes a big difference when you are used to driving in it. I work in an automotive dealership any a lott of customers come in in the fall and winter asking "how do I turn this **** off"(traction/stability control). Its pretty irritating for people who are experienced driving in slippery conditions.
/ skidding on black ice #66
I wonder why? Traction control will engage the other wheel when the primary drive wheel starts spinning. The Stability Control will actually apply the brake on one wheel in an attempt to return the vehicle to a straight line.
/ skidding on black ice #67
Ill wager you wont find a Subaru driver in any of those "displays".
larry
I don't think so...maybe just terminology.
to get another wheel moving, you need limited slip, positraction, call it what you want, but I don't think it's called traction control.
I thought that was related to the braking ability similar to stability control, but when the drive wheel has lost traction. It cuts the power to that wheel; never
thought it transferred power elsewhere. ??
terminology?
/ skidding on black ice #69
terminology?
By braking the wheel that is spinning, it forces the differential to transfer power to the other wheel.
A open differential always puts the same amount of torque to both wheels. If one wheel is spinning easily, the other side gets the same amount of torque but it cant do anything with it as its not enough to turn the non spinning wheel.
Aaron Z
Aaron, ok, so you brake the spinning wheel, but if that does not increase the torque to the non spinning wheel, what have you accomplished other than forcing rpm reduction down to some sane level where traction might be gained?. I thought an open diff sent power to the first wheel that will spin. ?
A closed diff or limited slip diff would actually drive two wheels, not one.
It used to be easy to order positraction or whatever marketing term the big three had at the time, but today it seems you have to order only the highest performance rear wheel drive model to get limited slip on the rear. Instead, it's all electronic nannies and braking control.
And even harder to find on fwd cars.
/ skidding on black ice #71
Daugen do you understand the relationship of the pinion and ring gear and the spyder gears and bevel gears on each axle shaft? If not, please look at this old video that explains it well.
If you brake the spinning wheel a bit it will slow it down, and slow down the rotation of the spyder gears, allow more "push" on the opposite bevel gear on the opposite axle. Remember if the both bevel gears are rotating at the same speed, the spyder gears are not rotating at all on their jackshafts.
Around The Corner (1937) How Differential Steering Works - YouTube
/ skidding on black ice #72
What it does in increase the torque needed to spin the wheel that has no traction so that increases the amount of torque sent to the wheel that has traction.
It can also put you sideways real fast if both back wheels break loose (have done that on purpose a time or two in my limited slip equipped '97 Volvo V90)
Thats because telling ABS to slow the spinning wheel is just a few extra lines of code in the ABS software. Adding limited slip takes hardware which costs a lot more.
Aaron Z
/ skidding on black ice #73
Thats because setting ABS to slow the spinning wheel is just a few extra lines of code in the ABS software. Adding limited slip takes hardware which costs a lot more.
My truck has all 4 systems. ABS, Traction control, Stability Control, and a mechanical type of locker called the Eaton G80 or "gov lock"
/ skidding on black ice #74
well, good info. But ABS is not defeatable in most cases so we need to know how to drive with it properly.
Yes there may be a rocker switch somewhere on a person's dash, but I defy you to find someone, other than us motorheads, who
knows what it means or what it does. they are going to slam on those brakes in a skid. BUT WAIT. Not in a FWD car. Need to get that word out...
Sure it is pop the abs pump fuse out (high amperage), abs disabled. Or pull 2 abs wheel speed sensor wires. Usually there is also an abs module fuse I wouldn't pull that one or you also loose all dynamic proportioning definitely bad if you go rear bias. Lock the rear wheels before front in a panic stop and you will experience spinning while braking. Same thing could also happen while braking in a turn (spinning in a turn) as a brake engineer I don't recommend doing any of the above. Most people in a panic situation will not out perform abs. Though it is possible
/ skidding on black ice #75
Anyone remember the old Jeep Wagoneer ad with quadratrac?
They would position the jeep with one front and the opposite rear corner wheel completely in the air and then drive... no spinning and no fancy electronics.
This was 40 years ago.
4wd is such a misnomer.
Normal: one wheel drive
4wd: two wheel drive
4wd with locking/limited slip rear: 3 wheel drive
AWD: true four wheel drive
do I have that correct?
Been driving my Kubota in the snow a lot this winter (no surprise!) and despite 4wd, have had to step on the diff lock numerous times to get myself though heavy snow with a load on. Need that 3 wheel drive...
Wonder if any tractor is true awd? probably too expensive..
Black ice is one reason why I study TireRack.com carefully. There are many good winter tires, and even some all season ones that have capability on ice.
Has to do with the silica and other gritty things I suppose they put in the rubber compound, which is also designed for low temps.
The Continental PureComp radials I put on my VW recently have that compound in them, and so far, they have been awesome this winter for a normal
all season tire, albeit one I researched carefully to do well year round. I have a 4wd Suburban for nasty weather, don't need snow tires on the car. And the tires on the Suburban, Firestone AT's, are amazing in the snow, but probably not as good on ice as the car. Now I just stay off the roads unless it's a true emergency. And since I don't have a blue light on my car anymore, unlikely that will happen.
The worst ice driving experience I've had was about thirty years ago here when everything was just a skating rink, about half an inch of solid ice on everything.
I don't know why I had to go out, maybe the fire company, don't remember. But I do remember driving down the very center of the road, trying to balance myself on the crown of the road, as our secondary roads are highly crowned for drainage, and there is a tendency to slip to the right. Since no one else was out on the road, I just very slowly crept down the center of the road to home.
/ skidding on black ice #78
<The worst ice driving experience I've had was about thirty years ago here when everything was just a skating rink, about half an inch of solid ice on everything.
I don't know why I had to go out, maybe the fire company, don't remember. But I do remember driving down the very center of the road, trying to balance myself on the crown of the road, as our secondary roads are highly crowned for drainage, and there is a tendency to slip to the right. Since no one else was out on the road, I just very slowly crept down the center of the road to home.>
And then came the super elevated curve and you were driving to slow!:D
/ skidding on black ice #79
As I understand it, AWD is no more "true 4WD" than any other vehicle. They still have differentials, there is just a limited slip differential between the front and rear wheels instead of a locking shaft that doesn't allow any slip and generally they use traction control braking to control wheelspin.
Some have locking front differentials, but those are generally 100HP or larger.
Aaron Z
/ skidding on black ice #80
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
CARORI 4' FINISH MOWER, 3PT (A64278)
CARORI 4' FINISH...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A67148)
2025 DELCO T/A...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
