Oil & Fuel Adding a Spin on Racor filter to a BX25
/ Adding a Spin on Racor filter to a BX25
The filtration is a little weak, its a 15 micron filter, its more for the water than a filter. I was after more of a filter and less worried about water, I think the Racor takes care of both. It would be real easy to add a valve to any install.
Yup.
IMHO the 2 micron Racor is superior. I cannot find a pore size for the Kubota filter with the valve some are using, but can for a Yanmar/Donaldson cross reference which puts it at 16 Micron.
To me, the Racor will provide superior filtration and superior water separation. Valves are easy to install if so inclined.
/ Adding a Spin on Racor filter to a BX25 #102
I think the Racor filter is a good upgrade for a BX or any tractor. The BX filter could be bigger. One thing I would like to point out is it not the filters fault that it is getting clogged. It is doing it's job. I know that when you buy diesel you are going to buy some water and dirt. If you are having frequent clogged filters you may want to rethink where you are buying your fuel, look at how clean your fuel container is, how you are transporting your fuel container, and/or how you are storing your fuel container. I also realize that clean fuel may not be available everywhere.
The BX filter is supposed to be checked every 100hrs and replaced every 500hrs.
The filter element on the L4240 is supposed to be cleaned every 100hrs and replaced every 400hrs.
I think the BX filter should be changed more frequently than what Kubota specifies.
/ Adding a Spin on Racor filter to a BX25 #103
If you are worried about the lift pump just put in a small inline filter that Kubota uses on the bx ahead of the lift pump. They are cheap and no mounting required.
/ Adding a Spin on Racor filter to a BX25 #104
The problem is the little BX filter before the lift pump plugs easily and I want to get away from that. I removed mine when I put the Racor on.
As far as my fuel goes I use a 5 gallon can. I look inside it and it looks brand new. My problems have occurred during winter. There is three things that could be a problem. Fuel gelling, water in the fuel freezing or dirt. I use an additive for gelling but that could still be a problem. The last three filters I've replaced allowed almost zero flow but when I cut them open they don't look that bad. There might be a fine silt in it but I'm not sure. I know I have zero problems with diesel in my truck and I get fuel at the same places.
That would defeat the purpose of the filter upgrade. Problem is the factory filter sucks! And clogs at the drop of a hat!
/ Adding a Spin on Racor filter to a BX25 #106
Scooby is usually OK with a bit of drift, so I thought I'd toss this in....
In terms of the filter Micron wars, consider using a fuel additive that de-emulsifies (as in coagulates) tiny water particles, as it will assist in water separation activity with any filter. This action is one reason I use Stanadyne, but I believe other products do this too (Optilube XPD ?).
If I understand the described Winter issues with the stock Kub filter, the type of additive I'm talking about may actually cause you to change the stock filter more often, but IMO that is better than having those tiny water droplets going through an injector. A Racor or any olde school cup separator with a drain cock will just have to be drained of water a bit more often, using addy's like I'm describing.
Rgds, D.
/ Adding a Spin on Racor filter to a BX25 #107
Not really, but you can also get inline screens that would take the damaging pieces out.
You said install the factory BX filter before the lift pump. That filter is precisely the problem
/ Adding a Spin on Racor filter to a BX25 #109
If your fuel is that dirty then your racor will be plugging with frequency too. 2micron filter takes out most everything. Just for interest I installed a racor on my front mount mower and left the inline in place ahead of the racor and the factory filter lasted 2 racor filters before it plugged.
/ Adding a Spin on Racor filter to a BX25 #110
That's why I went with the 10 micron Racor. Its still finer than the Kubota filter is reported to be rated at.
Also, inline electric pumps are designed to push not pull so I didn't think it was wise to add unnecessary restriction upstream.
/ Adding a Spin on Racor filter to a BX25 #111
Possibly but doesn't Kubota put one before and one after the electric pump on the bx? I know they do on the F series mowers.
/ Adding a Spin on Racor filter to a BX25 #112
Yes, I should have been more clear. My Racor IS plumbed before the pump replacing the feeble 1st stock filter. I left the second one in place as it does no harm & it could help if anything would ever come apart from the lift pump.
/ Adding a Spin on Racor filter to a BX25 #113
Rgds, D.
You know you might be on to something. I use Howes and there is a chance that is working against me in terms of clogging the factory filter. It also makes sense that its a good thing, you don't want a bunch of crap going through your fuel system.
/ Adding a Spin on Racor filter to a BX25 #114
Many large tractors, combines etc. place a inline filter just outside the fuel tank to catch any large particles before the go through the lift pump. They last 100's of hours before plugging and thats with 10+gal/hour fuel flow. If one on a small bx plugs regularly then there is a fuel cleanliness issue going on.
/ Adding a Spin on Racor filter to a BX25 #115
I don't think its fuel problem. There are to many people reporting the problem. There has been a couple people that have reported there sending units rusting out. That's possible with mine. It could also be the fact that the one on combines and such is designed to catch large stuff and the ones on a BX aren't that they are catching all the small stuff and plugging up. It could be a gelling problem. Someone also mentioned that maybe the filter media on a BX is designed to catch water and that is whats stopping them up.
Rgds, D.
Your right Dave.
Different additives perform in different ways. Some will help in pulling out the water in conjunction with the filter but some will emulsify the water and let it pass through the filter and engine. With the de-emulsifing additives, thats where the Racor models shine with their built in drains and clear bowls..
See water.. open drain... close drain.. drive away. Easy peasy. Other models require disassembly of the filter housing which not only takes more time, but wastes more fuel.
/ Adding a Spin on Racor filter to a BX25 #117
That's the reason I liked the $33 Goldenrod- nice easy to see clear bowl and drain valve. If they had a 5 or 10 micron filter element, then it would be better. I have to save money whenever it doesn't have hidden costs, you know.
/ Adding a Spin on Racor filter to a BX25 #118
I add Power Service to my 5 gallon cans prior to adding fuel at the pump. I over add. It is very common for me to see on extremely cold days when adding fuel to my BX2660 fuel clog up the screen in my oversized funnel and STOP the flow into the fuel tank entirely. This is treated fuel on ice/cold metal. The screen is all of an inch in diameter. I can only imagine what the fuel does inside the lawn mower-type filters on a BX. I'm done with them. The Racor has to be better. I'm going to look for room under the steering column by the battery for room. Maybe the engine heat will help?
/ Adding a Spin on Racor filter to a BX25 #119
Your right Dave.
Anybody that came up around old diesel tractors or heavy equipment (or grew up driving in Europe) is used to the reflexive Check/Drain as Needed routine.
To be fair to Kubota et al, with small diesels migrating into home tractor applications, aside from cost they probably spec'd these basic disposable filters in with the general attitude (No Maintenance) of Today's Consumer in mind.
Once people have a bit of diesel time under their belt, they appreciate the value of upgrading the filter. I'm a bit surprised that dealers don't quietly offer an upgrade package with a Sale - good value to the educated consumer there.
Rgds, D.
/ Adding a Spin on Racor filter to a BX25 #120
There are also fuel filter assembly heaters available; I'd be surprised if Racor does not offer one. That topic has come up on here recently (perhaps even in this thread), but they should be easy to find if you don't see that discussion on TBN.
Rgds, D.
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A60352)
2018 Sundowner...
2006 CATERPILLAR D6N CRAWLER DOZER (A62129)
2006 CATERPILLAR...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
WANCO LIGHT TOWER (A60736)
WANCO LIGHT TOWER...
2009 International 7300 Slickline Truck (A60352)
2009 International...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
