CHDinCT
Scooby, one more follow up question. Does that Racor filter have a fuel shut off? If not, how do you shut off the fuel flow in order to change the filter? Thanks again.
Just apply some red loctite to the bolts when reinstalling them.
No the Racor does not come with a shutoff.
In my opinion the Racor option is superior to the "factory" Kubota one like 4shorts and others have put on lately. The Racor has built in drains, and more importantly I believe the Racor filter material is superior and the filter has more filter area than the Kubota ones (albeit Racor is OEM for some model Kubota filters). That said, anything is better than the crap filter that comes stock on a BX.
What number is on your filter. The racor's go down to 2 micron while the standard Kubota filter is 30 micron. No comparison to the quality of filter. Kubota filters are slightly better than a screen.
Why do you think Kubota put a filter before the fuel pump inlet? To protect the pump![]()
To go though all that trouble and install an external filter and not want to protect the fuel pump (it's heart) is ridiculous in my opinion.
When that pump poops out, the guys who didn't protect will want to after they dish out the bucks to replace it. Do it right the first time.
Guys protect your fuel pumps!
Just say'in :dance1:
Who's this directed to?
I recommended installing the filter before the lift pump. Its Racor's recommended location as well.
I think he is referring to another post recently.....I too was planning on putting mine before the pump, not sure why you would not.
Yes, I installed mine after the lift pump. I also don't think its a very delicate lift pump and a lot of pickup trucks install the lift pump in the tank so its before the filter. Its that way on my Cummins. I agree, the cost difference is minimal. I installed mine after the lift pump because the thought of all the hose running back and forth bothered me. It seemed redundant but as someone pointed out in my other post its only about 6 feet of fuel line. I'm kind of stubborn and will probably leave mine the way it is unless I burn out a lift pump in the next few weeks. I still think I was plugging up my original Kubota filters because of very fine dirt and debris but was never sure.
Want kind of pump do they have and is it vunerable to debris? I don't know the answer to that question, I'm just asking. You guys keep this up I may be adding some more fuel line to mine to make it before the pump. I cut my filters open a couple of times and didn't get anywhere near that amount out of mine. I wonder what all that stuff is? I've wondered if mine isn't a problem with the sending unit starting to rust.
Also am I missing something with how I should install this? Don't you need to run a new piece of fuel line from before the lift pump and then a second piece back to the pump? Seems like the measuring I did it would take at least 6 feet of new hose.
