Backhoe Is the L39 stronger than the L4600?
   / Is the L39 stronger than the L4600? #1
Ducati07
Northern California
Kubota L45 TLB
I'm looking to purchase a new tractor loader backhoe and have been looking at the L4600 with a subframe backhoe attachment. Then, I was told that the L39 would be a better performing backhoe than the L4600. I was told that the L39 is a whole different machine and that everything about it is better and stronger. They said the L39 has a bigger pump and would out-dig and perform the L4600 on many levels. Seems a little strange to me since the 4600 has more HP but I know it all comes down to the pump. I wish I knew the output numbers of the pump comparing the two, and others.
Is there anyone that can backup the dealers opinion?
Thanks for any help with this topic!
   / Is the L39 stronger than the L4600? #2
I far as I have read the dealer is correct.The L39 is a purpose built machine vs the L4600 is a tractor with a BH added.Contractor vs home-owner comparison.
   / Is the L39 stronger than the L4600? #3
I was on a job couple of years ago and homeowner had a new L series with a hoe on it and he gave up digging a foundation for his garage in and called me to dig it.
I showed up with my b26 and was done in 2 hrs, there was several tree roots and it was hard but the tlb are purposes built machines.
We have a m5400 and I would never use it the like the b26 gets used.
   / Is the L39 stronger than the L4600? #5
It depends what you are going to dig. I have both a Case backhoe and a Kubota tractor with a backhoe attachment. Truth be known, I use the Kubota more. It is not nearly as fast but I am only doing maintenance digging. The Kubota has SSQA on the FEL so it is much more handy. If I were to be doing any serious digging, I would use the Case.
Well, the digging here is not friendly. I'm digging mostly rock, with some dirt thrown in. It is hard digging...not as bad as when I was digging up in the high country with a lot of granite. But, on my property I have a lot of river rock and in the area I see spots of what I call shale...not sure if that is the correct term but I do know that when I hit it..I end up needing a jack hammer to trench through it. So, I'd like to make sure and get the most bang for my buck having a machine to do what it can to get through the rough stuff.
I need to get by with only a mid size hoe at this time. I'd like to have a full size Case for the real digging and a smaller unit for detail work but this is going to be a one unit purchase for now.
Thanks for the input!
   / Is the L39 stronger than the L4600? #7
Sounds like you need the L39 backhoe.
   / Is the L39 stronger than the L4600? #8
Some of that could be because you are a more experienced operator, but you are right, dedicated backhoes are faster. I only get on one of mine a couple times a month and have to idle or adjust them down as it is. Like I said before, serious digging and occasional digging are two different needs entirely. For those with an occasional need, a tractor with a hoe attachment is fine. Power, reach and bucket selection are factors too, don't forget those.
   / Is the L39 stronger than the L4600? #9
Nothing makes up for seat time.
From the sounds of your digging L39 or L45 would be a good fit but the most important options would be QA backhoe buckets and a hydraulic thumb to pick the big rocks up and move them.
I would get a 12" bucket for hard digging 18 or 24 for everyday and a 36 smooth(no teeth) for backfilling and grading.
   / Is the L39 stronger than the L4600? #10
Ducati07: Also take into consideration the size of the bucket you are chosing. Sounds like a smaller bucket (12-18 inch) would suit you better which ever way you go. The 'performance' of digging with my B21 with the 12 bucket vs the 16 inch is much better.
2012 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2012 FORD F-550...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
2003 Big Tex 10PI...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
