Rake landscape rake
/ landscape rake #1
tjkubota93
Arlington, TN
Kubota bx1860
I have a bx1860 and want to get a landscape rake.
I have decided to get a 60" wide one so it will cover my tracks when turned diagonal.
I cant decide between a landpride lr05 or a everything attachments extreme compact tractor. Either way I want gauge wheels. They are about the same $.
Is the LP made in USA? The EA is.
Any helpful opinions/info? Anyone have either of these? Thanks.
/ landscape rake #2
If your tractor is a cat 1 3pt I would go with the EA rake, it has offset. I think that land pride is a Cat 0 with cat 1 pins. Nothing wrong with the Land Pride, I own their rake and like it a lot but would want the offset.
/ landscape rake #3
I would go with the EA rake also. It way more rake for the money than the LP. The Land pride LR05 is more for a garden tractor. It may be a little light duty for a BX.
/ landscape rake
Thanks I think yall are right. Now I gotta find the money. Then I gotta learn how to use it.
/ landscape rake #6
On a landscape rake, weight and width are your friends. Light ones bounce around fail to penetrate equally but rather ride over the surface. For me, wider is always better and whatever you think you might need, think about adding an extra foot.
/ landscape rake #7
I have a Woods LR72 Landscape rake and it works fine for light work behind the BX.
/ landscape rake #8
That model Woods is a great rake. I have the same model in 8ft --LR108--and it works great for me. Mostly use it behind a Kubota L4300 but also behind a JD 5520 to plow snow. It's not widely known but a landscape rake makes a great snowplow.
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2015 FREIGHTLINER...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
