Prince LSR valve just fitted .............................results
   / Prince LSR valve just fitted .............................results #1
Long shot
uk
Vap
Hi all I just fitted a Prince LSR 3060 3 to my home made splitter I have seen some threads discussing them so I thought I would post the results
The previous valve was a 95 lm auto kick-out with 3/4" ports running 1/2" hoses all round.
New valve set-up on same pipes (they do recommend 3/4" for the cylinder pipes )
Cylinder is approx 5" dia with 2.5" rod stroke is 33.5" it came off a caterpillar machine
Running at 1/4 throttle on my Leyland 272 at 2000 psi
STD valve extend time was 47.5 seconds
NEW extend time ......13 seconds.
AT full throttle 9 seconds .
Q.for the hydro experts how much faster would it go with 3/4" pipes ????????????
   / Prince LSR valve just fitted .............................results #2
Good to see a report of the LSR valve.
Thanks JJ thats why I posted them
Any idea on the 1/2" to 3/4" pipe swap
   / Prince LSR valve just fitted .............................results #6
Do the bucket trick to measure the hyd flow.
Use a 5 GAL bucket and cause the fluid to flow into the bucket for 6 sec times 10 or for 10 sec times 6.
That should compute the GPM for the engine speed you are using.
For the pressure use the the avg on the right of the chart.
   / Prince LSR valve just fitted .............................results #7
Long Shot,
With the information you already gathered you can figure your flow rate using the formula flow = velocity x area
in this case flow = 33.5 inch stroke / 9 seconds = 3.72 inches/second x 5" bore area of 19.6 square inches = 3.72 x 19.6 =72.9 cubic inches/second / 3.85 =18.94 GPM flow going into the base end of the cylinder.
figure tractor flow by using rod area times velocity or 2.5 rod = 4.9 x 3.72 = 18.26 cubic inches per second / 3.85 = 4.74 GPM
NOTE: 3.85 constant is derived from 231/60 231 cubic inches per gallon 60 seconds in a minute
1/2" hose at 19 GPM is over 30 feet per second
3/4" hose at 19 GPM is 20 feet per second
VOLVO EC240CL LONG REACH EXCAVATOR (A52705)
VOLVO EC240CL LONG...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
