Mirrors I got for Canadian tractor owners
   / Mirrors I got for Canadian tractor owners #21
Their nice, but it looks like you can't adjust them, "up or down" once bolted.
Only side to side.
Actually they are on a ball and socket type hinge and there's lots of up and down movement. :thumbsup:
   / Mirrors I got for Canadian tractor owners #22
I'm glad you found those here in Canada laminated. I saw 4shorts original post when he came up with that and I really wanted to do this.
Thanks to you both for the great ideas.
Your kindly welcome :thumbsup:
   / Mirrors I got for Canadian tractor owners #23
Do you have any vibration with these mirrors?
   / Mirrors I got for Canadian tractor owners #25
Hey lamanated, Can the mirrors in your link be adjusted up and down once they have been mounted ?
I couldn,t tell from the picture, or the product description. Are they the same as the ones 4shorts has used, or different ?
I know his can swivel up and down.
   / Mirrors I got for Canadian tractor owners #26
His mirrors mount different than mine but the swivel part is the exact same.
   / Mirrors I got for Canadian tractor owners #27
4shorts.......do they give you enough vision that I could use them to snowblow backwards without having to look backwards all the time?
Do you have a pic or can you tell me where you posted any of your chainsaw mount. Another good idea from you!!
I usually use my Polaris to harvest my firewood all summer, but I may start using the Kubota as I'm going to get a hydraulic dumping Weber Lane dump trailer. It'll save me a bit of handbombing.
   / Mirrors I got for Canadian tractor owners #28
I guess you could use them if your really used to using your mirrors and after looking at your avatar you'd do it ;)
Here's a few photos. Thanks!
   / Mirrors I got for Canadian tractor owners #29
I have similar mirrors and they work pretty well for snow blowing once you get them adjusted.
   / Mirrors I got for Canadian tractor owners #30
Thanks for the info Paul. Sounds like they will do the job.
1998 Wabash National 48ft T/A Flatbed Trailer (A56858)
1998 Wabash...
Wood Native American Statue (A56859)
Wood Native...
2019 GALYEAN...
New/Unused 4000PSI Hot Water Pressure Washer (A57453)
New/Unused 4000PSI...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
