Mechanical Rock Grapple
/ Mechanical Rock Grapple #1
pmhowe
North west North Carolina
Kioti CK2610
I ran across a picture of the Kenco triple tine rock grapple. Have any of you used one, and what is your experience? It looks like a really clever idea. Thanks for your input.
Ted, thanks for your post. I'm looking for the best way (using my L4240) to move individual large rocks in and around a stream bed. I'm thinking that the wicked root grapple or others like it would be best for scooping up lots of rocks and dumping in a pile. I thought the triple tine grapple, or one like it, would be best for picking up a single big rock and moving it.
As it turns out, the triple tine grapple is too steep for my current budget, so I am going to regroup and consider other options.
/ Mechanical Rock Grapple #6
Firefighter, I looked up your thumb. That looks like an affordable way to go. Did you have to reinforce your bucket?
Yes... I have a piece of 1/4 angle iron a
cross the top for a mounting point..
/ Mechanical Rock Grapple #7
I don't know what size rocks you are talking about but I use a "Thumb Like" grapple to work on and rebuild my old stone walls. Works pretty good for wall size rocks. Here is a wall opening that I made.
Hi Gordon,
The rocks you show in your pictures are about the same as the ones I'll be working with. I used some slightly smaller ones last summer in building a small wall across my creek. When we had our flood last fall, they all tumbled downstream. The force of the water really impressed me This summer, I'll go bigger. Meantime, I'm doing my homework. Thanks for your input.
/ Mechanical Rock Grapple #9
FWIW...I made a chain basket for lifting big rocks...
...started with a series of increasing sized chain circles and then used 2 longer chains to web it together...the 4 tag ends connect to a lift ring...
/ Mechanical Rock Grapple #11
Hi Slashpine,
That sounds like a neat idea, also. Do you have pictures?
I'll try to remember to take some and post them...the only issue is you have roll the rock onto the center of the splayed out basket then lift it ...not nearly as simple as a grasp/grapple...
(2) 3"X36" HYD CYLINDERS (A62130)
(2) 3"X36" HYD...
2018 International DuraStar 4300 26ft. Box Truck (A61568)
2018 International...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 66"...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
UNUSED KUBOTA K7875A EXCAVATOR BUCKET (A62130)
UNUSED KUBOTA...
