Hydraulic valve similar to 3-point hitch?
   / Hydraulic valve similar to 3-point hitch? #1
ishiboo
Oshkosh, WI
Kioti NX6010HSTC, Cat 279c
I am thinking of building a front hitch for my L3650. Not sure if it will be a full 3-point or simply custom at this point.
One thing would be nice would be instead of just using a regular spool valve, having a "level valve" like the 3-point hitch has, so that I can simply move the lever to whatever height I want the hitch at and it would essentially put it there. Obviously this would require the valve being configurable to the cylinder bore/stroke/etc. at the very least, making it a somewhat complicated proposition.
Are there valves out there like this for the general-purpose?
   / Hydraulic valve similar to 3-point hitch? #3
If I'm understanding your question correctly that valve will not perform the function your requesting. You would need a valve that includes some type of position sensing or an electronic system like those on larger tractors seen here. http://www.fronthitch.com/v3/pages/accessories.cfm
I'm not sure a manual valve is available for the application your seeking
   / Hydraulic valve similar to 3-point hitch? #4
This is what he said.
Quote: so that I can simply move the lever to whatever height I want the hitch at
   / Hydraulic valve similar to 3-point hitch? #5
All my stuff is older, so I'm not sure what's typical of newer "cuts", etc - but what I interpreted from the OP's question is that he wants position control.
On both my tractors, this is done internally using some sort of pilot valve and a "finger" that gets moved by the 3ph lever - when the lift is where you placed the lever, no hydraulic oil flows thru the cylinder - if the hitch raised on its own, the pilot valve bleeds off - if the hitch "sags", the pilot valve will raise it til the "finger" and the lift lever agree... Steve
   / Hydraulic valve similar to 3-point hitch? #6
That's a big ten four there Steve. I think J.J. missed the boat on this one.
   / Hydraulic valve similar to 3-point hitch? #7
It's not a who won this thread thing, or a who is smarter thing, I hope.
It's a collective, how can the TBN network help the OP.
Everyone will miss something at some point.
We all do.
   / Hydraulic valve similar to 3-point hitch? #8
So who said anything about winning or losing? I see two opinions on the table I agree with the second one, simple as that. Maybe I missed something.
   / Hydraulic valve similar to 3-point hitch? #9
I think the type valve with position control would have to have some form of feedback rod(manual or electric) built into it to accomplish what you desire.
Tennant 800 Ride-On Street Sweeper (A55787)
Tennant 800...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
