Kawasaki Mule 610 Upgrade Project (lots of pics)
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #11
Very impressive before and after pics. It's a totally different machine!!!
I see on your list of accessories that you bought a Kolpin gun boot. Where did you mount in and what do you think of it?
Eddie
Eddie
Thanks Eddie! Ya, I knew it would look different, but I didn't think it would be that different. :laughing: I was going to go with a black bed liner, but my son talked me into the desert tan. Which I now agree was a better choice for our area. The only other thing we went back and forth about was the wheels. I wanted plain ITP black wheels, he wanted the Exilir's. There was quite a bit of difference in price, but my main concern was dinging them on rocks and stuff as they are aluminum. Again, he was right. They do look nice, and we don't really do any hard-core rock crawling, so hopefully they'll stay nice for a long time. My plan was to take the ITP wheels and lay down some of the vinyl on those as well. The company said they hadn't seen it done before, but assumed it would work without issue. I am going to try it with my spare wheel.
I got this gun boot via Amazon. This is the Gun Boot 4 and Universal Bracket:
Kolpin 20205 Gun Boot 4.3 with Universal Bracket : Amazon.com : Automotive
I've had a GB on my quad for a number of years (not sure if it's a GB4, but it looks the same), but the mount is different. I got one for each side.
They are pretty decent quality. I think they are injection molded and not rotationally molded. They come with liner, but I normally never use them. I bought a really nice case for my shotgun and use that inside the GB instead. They are sized big enough for just about any weapon you might have, even with optics on them. These have the cover that snaps on and off. I have read that the GB6 (which opens up like a lid) is sort of a pain. I guess the cover doesn't swing up enough to stay open on it's own.... Anyways, the one on my quad and has seen rain, snow, mud, and deep water (over the muzzle end of course and not up to the opening), and has never leaked. And it has taken a beating on brush, small trees and on one occasion, a fairly big rock. I don't know if it would keep the barrel from bending in an accident, but then I wouldn't expect it to.
As to the mounting, I think I have a couple of pictures of them temporarily mounted. I asked my son to check and see. I'll post them if we did take some. The universal bracket can be used on quad racks, roll bars, and just about anything else you can think of....except solid flat (horizontal) things. Well, technically, i supposed you could mount it like that, but the weapon would be laying on its side. :confused2: Anyways.... they come with a lot of mounting hardware. They do have a mount for the boot that goes across the back of the cab (where my fuel packs are), but the 610 is so narrow, the stocks would be hanging out the sides and I'd be afraid of catching them on something. We only used the main bracket, and the little square U-bolts that come with the kit. They fit nicely over the bed rails. The bracket can be set for two positions (it's got 2 big slots, so really more than two, but for my purpose....2 :laughing: ). The first is with the nose of the GB inside the bed, kind of sitting in the curved recess of the front wall of the bed. The only issue (and it's purely cosmetic) is that for the passenger side, the bracket that pivots is flipped over and because of that, with the nose in the recess, the angle of the GB is higher than the drivers side. Not a huge deal really. The other position I think we'll use is with the GB pretty much parallel with the top of the bed rail. In that position, the nose of the GB is even with the front of the front bed rail and I think about 4 inches above it (the passenger side sits slightly higher because of the flipped bracket). We can tilt them down slightly as well. The 610 is small, so the GB does hang over the back of the bed by about a foot I think. In the nose down position, it still hangs over by about 6 inches. I think hanging over the back will not be an issue, as long as I don't back into something. By being in position 2, the only part of the GB in the bed is the actual mount, and the ends of the U-bolts and nuts. I suppose we could flip that around and put the nuts on the outside, but it would take a backup plate to make that work. Basically position 2 keeps the entire bed open for hauling things. We can load it up to the bottom of the brackets. If we really need to go higher, we could flip the mounts around and the GB would still be parallel to the bed rail, but it would be on the outside of the bed. Make sense? We did look at flipping the mounts around and putting the GB in it's most upright angle and sliding them way forward on the bed. That would put the nose of the GBs down near the battery and fuel tank on the outside of the Mule.
If I remember correctly, you have the Trans Mule which is wider than the 610. You might be able to get away mounting them with the cross-bed mount that Kolpin makes (you could use the universal bracket for this as well I think), or across the back of your headache rack and they would only hang out a little bit. And if you're only running it in the 1 seat mode, you could mount them on the bed rail and not have them hanging off the back.
Now, with all this being said, we haven't mounted them and driven it down the road, so I do have a little concern about shaking or wobble. The mount is pretty beefy and the bed rails seem pretty stiff, so might not be an issue. If they do want to flex from side to side, I was planning on adding a couple more bolts through the bed wall. If the nose wants to swing from side to side, I was planning on making a bracket that would attach to the front wall of the bed, and connects to the front mounting hole on the GB. But I won't be able to check any of this out until I come home again.
Sorry for the long post, just trying to pass on everything I know. :D Let me know if you have any more questions.
NV
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #13
Nice project. :) Looks a lot more capable.
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #14
Great project! Gives me a project for the spring. My father gave me a used Rice Farm Mule in really good shape, just idles poorly. I am going to turn it into a hunting vehicle and something my wife isn't embarrassed to ride in. I will hopefully do 1/2 as good a job as you have.
Thanks!
Thanks! It was a bit of a project, but just about everything was bolt on. The electrics and the console were custom and took most of the time. Well, that and the bed liner, but even that wasn't too bad. The vinyl took a few hours, but once we figure out the process, we got faster with each piece.
Good luck with your project!
NV
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #16
Really enjoyed your write up. Do you have any knowledge if 12x7 wheels with 5.0+2.0 spacing will work on the same Mule as yours without clearance issues?
Also, how did the 10" wide tires look mounted on the 7" wide wheels?
Thanks
Thanks
Thanks! And welcome!
I'm assuming you've got a wheel in mind that only comes in that backspacing setup...
Since a 5+2 would push the wheel in, depending on the tire, you may have an issue in the rear. I am running 10 inch tires, but the newer XC 610's are running 26X9-12's front and rear. You might be able to run those and gain back the lost clearance. Honestly, I almost went with 26X9-12 all the way around just to make it easier for a spare, but I was worried about impacting performance with the taller tire. However, after getting everything mounted.... I think I could have gone that way and been ok. Once these tires wear out, I will probably do that.
I'm not sure on the front.... I don't have any good pictures of the front suspension with those tires mounted. Since you're pushing the wheel in, I suspect any issues would show up during hard turns against the steering stops.
I do have a 2" lift installed as well, but I think I could have run the 12" wheels and not had any issues.
Here's a pic of the 10" on the rear. I think they look pretty good. The second pic shows how much balloon they have on the rims. It's not that bad and the tire is pretty stiff, so not a lot of sidewall flex. You can also sort of see how much clearance there is between the tire and the swingarm. There's probably enough to clear that backspacing, but you might run into issues with the frame on top during hard flex. The BigHorns are what Kawasaki is running from the factory on the XC's. They are a nice tire....
Good luck and post up some pics of the finished project. :)
NV
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #18
Have you noticed any power loss with the 25" tires. I noticed in your original post that you didn't think it was an issue, but wondered if you have noticed a difference after more use.
I work overseas, so I haven't had a chance to use the machine since we did this. However, my son has put some time on it and doesn't think it has had any loss of power going with the 25" tires. When we put them side by side, the 25's were actually about 1/2" shorter than the stocks tires...
The 610's aren't exactly power houses. We live around 4500 feet and most of our riding is above that, so I was happy there wasn't any power loss. :) If you are down at sea level I suspect you could get away with 26" tires as well...
NV
   / Kawasaki Mule 610 Upgrade Project (lots of pics) #20
I'm just starting a similar project on my Mule 610xc and would love to see the pictures but Photobucket says they are unavailable. Any other source?
Thanks
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
1996 JCB 506B Telehandler (A57024)
1996 JCB 506B...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
