Quick Disconnects not so Quick!
/ Quick Disconnects not so Quick! #1
the whispering oaks farm
Imboden, Arkansas
LS XR4046HC, Ariens 60" max zoom zero-turn- Cub Cadet 1050 Rider
I put a grapple on my LS XR4046HC and love it. my problem is the quick connects. when there is pressure I can't get them to attach for anything. I ended up buying Pioneer 6010-4p-dc connectors that connect under residual pressure. I still find it really difficult to grab the female connector and push that down and then push the male in with the other hand. I have been using a pair of channel locks to grab and push the connector and have a way of holding it. is there a special tool/handle made to do this with? I had shoulder surgery and it is just getting to be a not so quick connection.: Any suggestions? ( 20131106_082717.jpg
/ Quick Disconnects not so Quick! #2
Need to relieve the pressure after you turn it off by moving the control back n forth, then disconnect the line.
/ Quick Disconnects not so Quick! #3
If it's the residual pressure causing the problems get a small wood dowel and a rag to keep handy, use the dowel to release the pressure by bumping it against the ball after wrapping the rag around it.....Mike
/ Quick Disconnects not so Quick! #4
Here is what I do.. and I did notice you have two females on the machine and of course have two males on the implement. I have one of each.
Step one, when ready to take the grapple off. Turn off engine. Operate SCV both directions to relax pressure. If using electric/hydraulic. shut off engine, then turn on key again for power and active buttons on electric/hydraulic solenoid several times to relax pressure..
Step 2 Unhook the QC connectors. I put the male into the female on the grapple to keep them clean. and when I shove them together, I hold them together while pulling back on the outer ring of the female to relax the detent balls so that when I put them together I can do it quickly a couple of times, the idea is to "puke" out some of the fluid, then let the outer ring snap down, and hold the male connector. The idea of releasing some of the fluid, and we are talking about a few drops here, is so that no pressure can build up in the lines if they heat up by lying in the sun. Cover up the male and female on the tractor side by using the rubber covers.
When hooking back up, just make sure the tractor is not running, and hook up the plugs. I have never had any problems following this protocol. Since you have two male plugs on your implement, you could make up a short female to female hose to put over the two males, and let out a bit of fluid to help prevent pressure build up.
Yes it is the residual pressure, the only way I could get it to release was to take the fitting loose. it was so much pressure. I did try the moving the joystick in all directions also to release it but the pressure seems to be in the grapple. I let everything down and the jaws also. then shut down, turned my ignition back on to activate the electrical function and did the rotation thing. I bought the new connectors that will connect under pressure and it helps but I can't hold the female open and push the hose in.
/ Quick Disconnects not so Quick! #6
Anyone have the link for that tool that relieves the pressure?
/ Quick Disconnects not so Quick! #7
Murph has it right. Before you disconnect any hydraulic implement turn the engine off and then move the control lever back and forth 3-4 times to relieve any pressure in the tractor or implement. Then disconnect. The next time you reconnect it will be easy. No reason to beat up your self or your machinery.
/ Quick Disconnects not so Quick! #8
Ok, how are you at fabricating things.. I could give you some ideas if this is still a problem
/ Quick Disconnects not so Quick! #11
I have two ideas.. One my own, and one I read about. lets go with the other persons idea first..
Since you have two males on your grapple.. Get two females and put them on a short piece of hose, say 1 foot or less. Then on the other end of the hose put on a cap, loosely put on by your fingers. Now as soon as you relieve pressure on your tractor and unplug the male connector plug it into the female "dongle". Do this with both male connectors. Empty the dongles periodically by unscrewing the caps and let the oil drain out. They will keep your connections clean from dust, and pressure will never build up in the lines.
My idea was to build out of a set of channel locks a "squeezer" with a U shaped piece of steel welded to one set of jaws of the channel locks, then another T shaped piece of steel with two holes drilled in the ends for bolts to bolt on a piece of hard wood like oak so that the ball lpresses into the face of the oak in the middle of the span, and the U shaped piece of steel is behind the back edge of the male coupler. This allows you to squeeze the ball back with a lot of pressure to make it "puke".. A rag over the assembly would be a good idea unless you want a shower.
But I think the coupler dongle would be easier to make and work without effort.
/ Quick Disconnects not so Quick! #12
There 2 ideas for the low low price of nothing!
I think I will try the short hose trick first, that sounds easy and it will also double as a cap on the ends. I could just leave it on until I need to hook it up again. Thanks Guys, sometimes it takes a few good minds to work these things out. too bad mine is fading.
/ Quick Disconnects not so Quick! #14
Please let us know how it works out.. thanks.
/ Quick Disconnects not so Quick! #17
This tool has a fork that holds the body of the disconnect and the other side of the plier type tool pushes in the button to relieve the pressure. Looks like a pair of weird pliers.
/ Quick Disconnects not so Quick! #18
Got this from a old thread posted by JJ
I have mentioned this many times before. You only need one QD fitting. a short hose, and a plug in the end of the hose.
When you remove the attachment from the machine, plug the adapter in to the matching QD. This will let any fluid that may expanded, seep into the adapter hose. This may cause only a few psi of air in the adapter. If the hot attachment ever cools down, it will suck in a little air.
/ Quick Disconnects not so Quick! #19
I've been there/done that and still cursed myself silly... until I remembered that I wasn't also relieving the pressure to those two connectors because, on my control stick, if I'm going to open/close my 4in1 bucket, I have to press & hold in a button = which engages those two couplers.
Once I also held the button in and again moved the control stick back & forth then the couplers engaged/disengaged without a problem.
/ Quick Disconnects not so Quick! #20
I wish that they had a "schrader valve" type fitting that could go inline somewhere to let the pressure off. My skid steer is not too bad (to hook up) but attachments that warm up in the sun can still make it necessary to break a fitting. My tractor on the otherhand.... I almost wonder if there is hyd oil sneaking PAST the sol.even when not energized. And believe me I have 8 hyd. attachments and know the proper disconnect procedure. I keep an adjustable wrench in all the machines using these attachments. The only ones that do not give me trouble are the one's with motors rather than cyl's. "Quick connect" is aptly named as an "easy out".:muttering:
Almost tempted to switch it all back to the old "Pioneer" type ag fittings, they were easy to "burp" if needed.
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
FUEL PUMP W/NOZZLE (A60736)
FUEL PUMP W/NOZZLE...
2016 CAT 259D Compact Track Loader (A61166)
2016 CAT 259D...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
2022 North Star Pressure Washer (A60352)
2022 North Star...
2004 VE Enterprises 500BBL Frac Tank (A60736)
2004 VE...
