How many of you guys use battery operated impact wrenches?
   / How many of you guys use battery operated impact wrenches? #21
I have air, corded and battery, the battery gets used the most. I have Makita, check out the brushless units the last twice as long on a single charge.
   / How many of you guys use battery operated impact wrenches? #22
I have a dewalt 18 volt 1/2 drive love it. I also have a 1/2 chicago electric corded one also that works fine.
   / How many of you guys use battery operated impact wrenches? #23
Makita apparently has two versions of their 18V lith-ion impact with two different ft lb limits. One would be a heavy duty and one a lighter duty. Does anyone know anything about the comparison between the two and if one is a better buy over the other?
   / How many of you guys use battery operated impact wrenches? #24
Which two Makitas are you looking at?
   / How many of you guys use battery operated impact wrenches? #25
   / How many of you guys use battery operated impact wrenches? #26
Weight and torque is the big difference the 450Z is much more powerful @ 325 ft lbs vs 170 ft lbs of course it weighs more too seven and half pounds vs 3.5.
Really kinda depends on what you want to do with it. If its wheel changes you want go with big one the 450Z. Is interesting that the prices are so close. No battery included but you already know that right ;)
   / How many of you guys use battery operated impact wrenches? #27
I know the torque and battery things but here must be something I'm missing for the prices to be so close.
   / How many of you guys use battery operated impact wrenches? #28
IMO not really...prices on bare tools are pretty reasonable. Its the batteries that really cost, especially the 3.0A batteries that these tools really need to perform. A lot of times to make certain tools more affordable they will offer only one battery in a kit. I think Milwaukee does that with the driver the op originally linked to. Or smaller amp hr batteries. Compare pricing at CPO or the HD website. And like someone else said already combo kits sometimes offer the best deals.
I've read posts about the 450Z here on TBN before. I would consider that one as more of a shop tool than a general job site tool. Wouldn't want to lug it up a ladder :)
Was just looking around...CPO is offering a free LXT battery with purchase of 2 bare Makita tools
   / How many of you guys use battery operated impact wrenches? #29
correction on my post above, i knew it had a model number 450, and thought it was torque, now i see it's only 325..... but it is heavy.
i usually only use it for lug nuts, and i did use it for the big lag bolts on the new deck railings this year.
   / How many of you guys use battery operated impact wrenches? #30
So the 450 will take off lug nuts? Is it adjustable for torque? Are you really happy with yours?
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2000 425 Panther Safari Rv (A49461)
2000 425 Panther...
