DIY Cab for Kubota B2620
   / DIY Cab for Kubota B2620
As an aside, kudos to my wife who came out to help me get the front and top panels up yesterday. She also stopped by later to bring me some "shop" beer.
I discovered why it's not advisable to open the cardboard package containing aluminum beer cans with a razor knife.
I tacked together the door for the left side yesterday. I used 14 gauge 3/4" square tube, screen door hinges with removable pins.
I'll add pics tonight.
I've decided to build a door for the right side as well instead of just a window. That way I'll be able to pull the hinge pins and remove both doors in the summer and leave the top on for shade as recommended by mikehaugen.
I made the right door as well but ran out of shielding gas late yesterday afternoon. So tomorrow I'll get the cylinder filled and finish up the last few welds on the door.
I really like my Everlast MIG welder. Today I put 1/8" plexiglass on the left door and installed a storm door latch.
I'm closing in on it.
PS The glass is actually going to be clearer than it looks. There's a lot of dust on it now and that one section still has the protection sheet on it.
   / DIY Cab for Kubota B2620 #26
What method did you use for cutting the Plexiglass? I've heard of many and want to know what works best before I start my project.
   / DIY Cab for Kubota B2620 #27
Thicker plexiglass (1/4" or so) cuts well with a circular saw if you need straight cuts.
   / DIY Cab for Kubota B2620 #28
Yes, circular saw (table) with a good blade lots of teeth is best. Proper speed so you don't burn/melt it is key for a fine edge. Otherwise, sanding, and flaming for a professional finish (built a couple of aquariums).
I used a plex cutting knife to score halfway then snapped at the edge of a workbench. It worked Ok but was a lot if hand work.
Later I used the angle grinder with a metal cutoff blade then sanded the edge.
I got the other door built and hung so the cab is mostly enclosed. I still need to put some gaskets around the doors and other places and lay a rubber sheet down the back and under the seat.
I used it last night to plow and it is noisy with the reverberations from the engine but I wore hearing protection.
Question about heaters. The ones I've looked at have 5/8" hose bibs. Does anyone know what the 2 different size hoses are on the Kubota B2620? Does it matter where in the system you tap in? I see there are Y adapters of various sizes with 5/8" outlets for the larger of the two hoses but I dont know what size mine is. And there is another smaller hose on the tractor but I don't know if it is 5/8 or not. I'm looking at a Maradyne universal heater.
Thanks for any assistance that can be provided for the hose sizes.
2021 Kubota SVL75-2 Track Loader (A56435)
2021 Kubota...
More info coming soon! (A56858)
More info coming...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
