M8540/M9540 540/1000 rpm PTO Conversion install
   / M8540/M9540 540/1000 rpm PTO Conversion install #41
I'm curious if a noticeable savings in fuel consumption can be noticed.
My understanding is that for a given load, a diesel engine uses about the same amount of fuel regardless of RPM. I was hoping to reduce noise when operating the PTO generator at loads that my L3710 can handle at a lower, quieter engine speed since the tractor is running adjacent to the house it's powering.
Regarding other tractor brands and models, the design requirements for a pto speed increaser drive the cost high. It should be (1) shaft mounted and supported (2) rotate the same way (3) provide step-up of about 50% (4) input and output on the same centerline (5) include a bi-directional torque resistance (6) sealed oil-bath housing (7) compact and light-weight. For a time there was one like this (Comer A-20A from Italy) but it was priced around $1k when I inquired.
The Hub City Model 390 PTO Speed Changer is in the $2k range. Ouch!
Thanks to you both for such informative threads!
Yep, I understand the noise thing for stationary operation for sure!!!
I am just assuming theirs an economical reason that manufacturers are selling tractors with reduced engine speed PTO operation. I think JD even calls theirs ePTO (economical) and talk about cheaper operation??
   / M8540/M9540 540/1000 rpm PTO Conversion install #43
An advantage with my L5450 conversions was the pto gearbox was already designed to have the extra gears - earlier serial numbers had included it but I'm guessing the accountants or product liability lawyers had weighed in. With the back end lifted the oil ponded forward - no need to drain any. You can try that on your next one:thumbsup:
Take care - good job, good posts Dick B
Yeah I parked on some blocks but still had to catch some fluid. To swap cases you are about 1.5" from the bottom of the housing.
I think the omissions we see in later models is always dollar driven. Most operators wouldn't even notice that the tractor wasn't equipped with it anyway.
   / M8540/M9540 540/1000 rpm PTO Conversion install #45
......manufacturers are selling tractors with reduced engine speed PTO operation. I think JD even calls theirs ePTO (economical) and talk about cheaper operation??
I think the "economies" of lower-rpm operation are from lower friction losses, less waste heat, less mechanical wear of everything. But the actual job being done by the pto shaft uses the same amount of power - so fuel savings are small. Reduced noise may reduce operator fatigue - so you won't take up hang gliding, short out the grid, raise the crime rate, get your dad punched over a can of soup, etc.
I think the "economies" of lower-rpm operation are from lower friction losses, less waste heat, less mechanical wear of everything. But the actual job being done by the pto shaft uses the same amount of power - so fuel savings are small. Reduced noise may reduce operator fatigue - so you won't take up hang gliding, short out the grid, get your dad punched over a can of soup etc.
Heheheheheh. Good one!!! :)
   / M8540/M9540 540/1000 rpm PTO Conversion install #47
Great write up and especially great photos. They really tell the story.
   / M8540/M9540 540/1000 rpm PTO Conversion install #49
I lately learned that more hp can be delivered through an equal shaft at a higher rpm. That was probably not worded the right way but I wonder if that was the original reason for 1000 rpm pto's, as I remember it seemed that they first appeared on the higher HP tractors.
:confused3: I'm not clear if this apply's to gear box's and other components as well.
   / M8540/M9540 540/1000 rpm PTO Conversion install #50
...... I wonder if that was the original reason for 1000 rpm pto's, as I remember it seemed that they first appeared on the higher HP tractors.......
PTO speeds are chosen to serve the implements in each market. Some quite small tractors made in Japan and other parts of the world have had multiple pto speeds for years, mostly to power various harvesting machines.
Safety and failure are issues if an implement is driven beyond its design speed, so higher-speed ptos are no longer common on homeowner machines. Attachments of different speeds now typically are segregated by front/rear mounting, different shaft coupling style and rotation.
Multi-speed rear ptos have re-emerged on larger tractors - perhaps because their operators tend to have more machine training and experience ?
An oddity I noticed. I have a JD M1008 10ft twin spindle brush cutter. It was available in 540 or 1000 pto speed. Mine is 1000 rpm version. Had to rebuild slip clutch. The 1000 version uses fewer clutch discs than the 540 version. Hmmmmm?? Maybe someone with technical knowledge can explain that one? :)
   / M8540/M9540 540/1000 rpm PTO Conversion install #52
Power is torque times rpm. For the same rate of power delivery needed, the 1000 rpm version can operate at about half the input torque of the 540 rpm version, hence the drive line and slip clutch can be less massive.
Another example is to think about the tractor climbing a hill. Compare the relatively high rpm and low torque of the engine crank with the much lower rpm and much higher torque at the rear axles. Same principle.
Thats what I thought but wasn't sure. Appears to be easier on the PTO system including shaft assembly?
   / M8540/M9540 540/1000 rpm PTO Conversion install #54
Yup. Double the speed & you halve the torque. In theory with half the torque you need a PTO shaft that is half the strength, which can mean half the weight & half the price. Reality doesn't always match theory, but a 1000rmp shaft transmitting the same HP as a 540rpm shaft should be lighter & cheaper.
   / M8540/M9540 540/1000 rpm PTO Conversion install #55
:thumbsup: Now that you put it that way, (I knew there was a reason) I understand!
   / M8540/M9540 540/1000 rpm PTO Conversion install #56
Excellent explanation.
   / M8540/M9540 540/1000 rpm PTO Conversion install #57
Sorry to bother you. I was just wondering if you had the part number available for this kit?
I have a M9540 and am looking to upgrade to having dual PTO
Thank you.
No bother at all. I'll go out to the shop and see if I can find the wholegoods kit number. Stand by.
Thank you.
I can't believe I didn't list the wholegoods part number for this kit in the beginning.....
Kit # 3C081-97711. Kit will fit 8540, 9540, 8560 and 9960.
Welcome to TBN!!!
Let us know how you get along if you install the kit. It's pretty simple.
Again, welcome to TBN!!!
   / M8540/M9540 540/1000 rpm PTO Conversion install #60
Welcome to TBN!!!
The EPTO option on my M9960 was dealer installed when I purchased the tractor. EPTO is the same as 540/1000 aside from gear ratio.
When installed, I asked the dealer for the OEM 540 housing assembly but was told that they MUST return it to Kubota.
Were you required to return the OEM assembly to your dealer when installing yours?
SDT
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
Case Titan 3530 (A56438)
Case Titan 3530...
Kubota Snow plow with subframe
Kubota Snow plow...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
