New Holland 1620 / 7108 loader troubles.
   / New Holland 1620 / 7108 loader troubles. #11
Regen is when the valve rod side work port is blocked and the rod side fluid is mixed with the pump flow into the base end and that causes the fast dump.
Many millions of loads have been dumped with out regen. It isn't necessary, but helpful at times.
   / New Holland 1620 / 7108 loader troubles. #12
It seems you have your solution. But for what it is worth, we had a similar situation with a Kubota B7800 would only turn the hydraulic motor on a post hole digger one way. We had the motor on the bucket curl hydraulic circuit. The dealer told me to push the curl function valve past the normal detent (which took an intentional pressure ) to get the motor to spin (both ways). It did! Maybe useful, Dave Howell
Thanks but I tries that also...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
ITEM LOCATION (A53084)
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
JOHN DEERE 5425 TRACTOR (A54756)
JOHN DEERE 5425...
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
