Landscape Rake to Clean Cleared Land
/ Landscape Rake to Clean Cleared Land #1
Catchad81
Notasulga, Alabama
Kubota M7060
Hello all. I have found this forum very useful in the past in researching items and finding answers. Maybe even posted once before.
I've been destumping and clearing about 30 acres with a dozer and root rake. In the past, I've had larger tractors and disk harrows to use for plowing the ground and taking care of the small limbs, roots, etc. Where I'm at now, I don't have access to the larger stuff, only my Kubota MX5100 and three point disc. Also, other locations have been used for pastures, etc. and some sticks left wasn't that big of deal.
My question is in regards to landscape rakes. Being that this clearing operation is at my homestead and I want more of the smaller stuff gotten up, will a landscape rake help me with that propose? I see it as a scaled down root rake, even if I have to take every other tine out of it for use. I also would use it for lighter grading in the future around a horse arena.
Researching these things, I see heavier is better. I like that theory anyway. Due to pricing and availability, I've narrowed my models to the Taylor 4500 series (heavier model) and the Everything Attachments Severe Duty model. Thinking of going with 8' to cover more ground. Rural King has the Taylor Way listed and will ship online as will Everything Attachments. Regarding gauge wheels, I can get them with the Taylor Way model for about one hundred more dollars over the cost of the EA model without. Are they worth it if I go with TW given the small amount?
I've read good reviews on the EA brand. Anyone have comments on the Taylor Way model? The only negative I can tell in the pictures of the TW are that the tines are not necessarily locked in a slot at the rear to keep them straight. They are in a notch, but it doesn't appear to have a bottom that forms a slot.
Thanks.
/ Landscape Rake to Clean Cleared Land #2
Thanks.
I went with the EA extreme duty on my MX5100. This thing is a real beast. Heavy as he!!, and rides very smooth. Hard to beat for the price.
Anyone have comments on the Taylor Way brand?
/ Landscape Rake to Clean Cleared Land #9
Researching these things, I see heavier is better. I like that theory anyway. Due to pricing and availability, I've narrowed my models to the Taylor 4500 series (heavier model) and the Everything Attachments Severe Duty model. Regarding gauge wheels, I can get them with the Taylor Way model for about one hundred more dollars over the cost of the EA model without.
I have an ETA Landscape Rake and a Ratchet Rake, by Ratchet Rake, LLC.
While the ETA Landscape Rake is EXCELLENT QUALITY it will not serve as a subsurface Root Rake even with every-other-tine removed.
Gauge wheels on a Landscape Rake are useful for final grading as they give a level finish. Downside is they stick out a long way when the Landscape Rake is angled, which limits maneuverability, and they are a pain to bolt on and remove. You have to be careful not to bend protruding gauge wheel brackets against obstructions when making turns. (My first lesson was $50) ETA's gauge wheels and supports, which are from India, are not up to the quality of the rake itself. Gauge wheels do not castor well and the axles bind up with trash.
The Ratchet Rake has two rows of teeth, one row "down" oriented across the bottom of the implement, which will pull roots down to 2" deep in moist soil. Ratchet Rake is The Berries for tearing out brush in general. It will do light grading. I often have the Ratchet Rake on the FEL bucket and my Rollover Box Blade on the Three Point Hitch at the same time and they complement one another when grading.
Picture #4 is all grape vine roots.
Note: Some pictures show Kubota B3300SU, predecessor to Kubota L3560.
