What do you call getting unstuck using the FEL?
   / What do you call getting unstuck using the FEL? #51
Bucket crawl is my term
   / What do you call getting unstuck using the FEL? #52
I can't stop laughing at your definition because it's so detailed...must respectfully disagree about one point: I had all four tires spinning in reverse with the diff lock engaged,and the tractor would not move, so I was STUCK. Using the FEL bucket to get UNSTUCK is a whole 'nother story...I was STUCK, period....:laughing:
Disagree. You were just "momentarily detained". Truly stuck means a chain/winch/rope was necessary to pull you out. :thumbsup:
   / What do you call getting unstuck using the FEL? #53
I like your definition of stuck. You stuck when you need outside help.
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
CENTURY 1000 GALLON SPRAYER (A52708)
CENTURY 1000...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
LOT: Assorted Clamps (A59076)
LOT: Assorted...
30KW GENERATOR (A58216)
30KW GENERATOR...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
