Is an 8ft 3 point brush cutter to heavy?
   / Is an 8ft 3 point brush cutter to heavy? #1
trook
Gold Member
North Central Mississippi
JD 5075E Cab
I am considering a Kubota 7060 or JD 5075E cab 4x4 tractor. I need help from y'all to determine whether or not a JD MX-8 or Bush Hog 3008 3-point rotary cutter will require the FEL to remain on the tractor to counterbalance and ensure enough weight is on the front of the tractor.
I want the ability to remove the FEL while transporting on a trailer but still have the 8-ft cutter on the rear. I want to make sure I have enough weight on the front to steer effectively so that the "tail does not wag the dog". Weights up front are out of the question because, from what I understand, you can't have a FEL and weights and I intend to keep the FEL on the tractor unless I am transporting it (which will occur every 4-6 weeks).
The other day, I experimented with a JD 5075E cab and MX-6 cutter, and the tractor had enough weight up front. However, they didn't have a MX-8 for me to try. The MX-8 weighs about 500 lbs more than the mx-6.
These tractors weigh approximately 5,500lbs without the FEL or loaded tires.
Thanks.
   / Is an 8ft 3 point brush cutter to heavy? #2
an mx-8 is not to big but you are going to want front weights just for insurance. I run an mx-10 off the back of my 5083E and I won't run it without the loader on. I haven't tried it with weights yet since its handy having the loader on to push stuff out of the way.
Also, You can have either a loader or front weights just not both at the same time. The weight bracket stays on the tractor and you just remove the suitcase weights prior to installing the loader.
   / Is an 8ft 3 point brush cutter to heavy? #3
I carry a JD M1008 (10') with my M9540. I hate cutting with FEL on as I'm normally cutting around stuff and in tight spots. I built a weight rack and carry 840lbs of suitcase weights. It's not useable without the weights. My tractor's shipping weight is 5500lbs.
I take a LOT of pictures, but just realized I don't have any of the tractor carrying the cutter or of the weight rack with weights on.
Have you considered a semi-mount or pull-type cutter? I can't use one in my conditions, but maybe you can??
Edit: Forgot to mention. My Brother has a 20' pull-type Bush Hog. I can pull it and make good time unless trying to cut heavy wet grass short, then I gotta gear down a little. The tractor's you are looking at would handle a 15' pull-type.
   / Is an 8ft 3 point brush cutter to heavy? #4
Pretty much along the lines of what ovrszd said, we have used/use 3PH and pull type. We went with a 10' pull type for our main cutter, haven't used the 10' 3PH in years. With the 10' 3PH, we have to have FEL and don't want to bother with weights.
   / Is an 8ft 3 point brush cutter to heavy? #5
I run a 7' Frontier RC2084 cutter (1100lbs) on the back of a 5075E.
With the FEL off the front of the tractor , you can sort of feel it back there if fully raised with zero weight on the mowers rear wheel, but not too bad. Maybe I could get the tractor to wheelie if I really tried in a high gear, but not enough that I seriously considered buying front end weights for it or even think about it when the mower/wheel is touching the ground. Instead I consider mowing w/ bucket or forks on to lift the big branches/obstacles that I inevitably encounter when mowing field edges.
   / Is an 8ft 3 point brush cutter to heavy? #6
And someone can correct me if I'm wrong, but I believe a 7' 3pt cutter would exert almost as much leverage on the tractor as an 8'. Reason being a 7' is generally a single spindle so is generally longer from the 3pt to the tail wheel as an 8' which is dual spindle. I think that longer design would almost offset the difference in weight.
   / Is an 8ft 3 point brush cutter to heavy? #7
I think your on to something there. I don't have any numbers to justify it but I would agree with you. Only thing you have to be careful of is comparing a light duty to a heavier duty mower.
   / Is an 8ft 3 point brush cutter to heavy? #8
Bushhog lists the 3008 cutter about 30# lighter than the 307 cutter.
Yes typically a twin spindle 8' cutter is going to exert less load on the tractor than single 7' cuter.
A 7' cutter has to be roughly 7' x 7' which is 49 sq ft minimum of deck. With the center being roughly 42" behind the hitch.
An 8' cutter only needs to be 8' x 4' which is a 32sq ft deck. And centered only 24" behind the tractor.
   / Is an 8ft 3 point brush cutter to heavy? #9
Thanks.
Our experience is that most twin gearbox 8 ft cutters will streak in the center when lifted a little to clipping height. A 7 or 10 ft does not have that inherent problem. Ken Sweet
Ken,
I'm not sure what you mean whey you say "streak". Do you mean they leave uncut grass once the cutter reaches a certain height? The two cutters I am considering are the JD MX-8 and Bush Hog 3008.
2018 Dodge Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Dodge Ram...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2019...
1R CULTIVATOR, 3PT (A52708)
1R CULTIVATOR, 3PT...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
3T HYD TILT BUCKET FOR MINI EXCAVATOR (A52708)
3T HYD TILT BUCKET...
1846 (A58374)
1846 (A58374)
