FEL Suddenly not working on JD 2520
   / FEL Suddenly not working on JD 2520 #1
lowechj
Member
Huntsville, ON Canada
Kioti CK3510SE
Went to use my tractor this morning the " joystick " was very stiff to move and the FEL would not raise up, hydraulic fluid appears to be ok in the sight glass. It was working fine when I parked the tractor the day before. The rear three point works fine as the snow blower would raise and lower and the tractor would move. The bucket is about 1/2" off the ground so I can still use the tractor for snow removal but it was awkward at times going forward as the tires would sometimes spin.
Any ideas of what to look for would be very much appreciated.
   / FEL Suddenly not working on JD 2520 #2
First, unplug the quick connects and reseat them. If that doesn't fix the probem...Does the bucket curl/dump normally? If so, swap the lift and curl hoses around, and isolate the problem to either the loader or tractor.
   / FEL Suddenly not working on JD 2520 #3
i had a 3720 cab and the fel would not work - found the cable under the joystick had come off, had to remove panel to gain access.
The joystick seems very stiff, when I pull back on the stick nothing happens usually you hear the noise that the system is working. I used the tractor yesterday for about an hour moving snow and everything worked fine, even when I parked it in the garage the loader lowered like normal, this morning it won't move in any position
I looked under the tractor after dinner and I was looking for something like a cable or linkage that might have come off but I couldn't see anything that appeared to be disconnected
   / FEL Suddenly not working on JD 2520 #6
Is there a lockout on the side of the joystick to prevent the loader from operating.? Just a thought.
   / FEL Suddenly not working on JD 2520 #7
That was my thought. My JD 512 loader has a black knob on the outside that when pushed in, locks out the loader controls. Not sure about the smaller loaders. First time I noticed it was the day I got it, and mounted from the wrong side. After a little WTF moment, I saw it. Darn glad I didn't call the dealer. #Embarrasment
Sent from my LGL35G using TractorByNet
   / FEL Suddenly not working on JD 2520 #8
That was what I was going to say to check as well.
There is a sliding bolt on the front of the panel below the joystick that allows you to lock out the joystick functions. It may have been moved by your heal when getting on, off or just while turning to watch the blower.
   / FEL Suddenly not working on JD 2520 #9
Is your garage heated? Could ice have formed around the linkages?
   / FEL Suddenly not working on JD 2520 #10
Moisture in cable housing froze limiting cable movement
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
2009 Ford Escape Hybrid SUV (A50324)
2009 Ford Escape...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
