Input from the forum?
/ Input from the forum? #1
yarg
UP of michigan
L48 Kubota
Hello Forum Visitors,
I am finishing a project of a small water well drilling machine and would like your input on a couple of options I have in the final make.
Here are my questions of the forum:
1. If you had the choice of having the main drive head powered to 162 RPM at 600 ft lb torque or a 100 RPM head at 750 ft lb torque, which would you want and why?
2. If given a choice between a self priming mud pump able to provide flow to 196 ft of head or a need to prime mud pump able to provide flow to 320 ft of head, which would you prefer and why?
Foot note-------The cost of question one is almost neutral, the cost of the self priming pump is huge ( $1,100 ) , this may change answers?
Thanks to any and all who provide input.
Yarg
/ Input from the forum? #2
I would go for the slower RPM and more torque and the pump would be a no brainer go with the one with the greater head pressure which would allow for deeper drilling. Priming shouldn't be a large issue as long as you have a water tank handy. You could even plumb it in with a valve to a tank and a checkvalve deliver water to the pump till it primed then the checkvalve would keep it from backflowing. I quick disconnect to it would make it less bulky to handle.
/ Input from the forum? #3
I would say it depends on what you are drilling, Michigan area I'm asuming.
I would say if mostly light soil & gravel to a few feet then sand stone gravels and harder materials intermixed. Then the higher speed to move thru the materials faster and pump with the self priming as the sub surface materials are lighter than heavy granite found out west. Then if the stuff is more gravel and sand the higher torque and higher flow will be needed as the material will want to grab the pipe as it turns and the high flow will be needed to push into the surrounding materials and stabilize the hole as well as bring up the cuttings.
Mark
/ Input from the forum? #4
My experience is with a 24x40 vermeer directional boring machine. How deep are you going to go? I do know you want the biggest torque you can get. The rotational speed is important also as it quickly burns things up with out a bunch of water for lubrication. I would go with the pump you have to prime ,but remember frozen water doe not flow and you are going to use alot of water.
Thank you all for input.
It is clear that torque is more important than speed. Being inexperienced at the actual drilling aspect, I thought input was in order. I will also be keeping the pump that needs priming as its specs are better and I can acquire it for far less. I rigged a couple valves and a priming funnel system along with a pick pu check valve and in less than one minute, had it primed and running strong. A byproduct of the move to the higher torque motors is moving from 4800 lb hoist to a 5400 lb lift, push force.
I liked the high RPM speed but most units run in the 80 to 120 RPM range so at 100, it should do well.
Around here we have everything from sand to hard rock formations. On the first big test I found going through some large boulders and major rock filled clay, the bit would stall and there was caving due mostly to my inexperienced mud handling. With the original pump capping out at about 37 PSI, keeping good flow was also difficult. Lifting cuts out was not working well. More torque, more PSI and flow= solution?
Gray
/ Input from the forum? #6
FLOW is more important than PSI in this type of application, however PSI develops do to resistance to FLOW. So if you are seeing a spike in pressure that means cuttings are building up and you need to slow the down speed and let the FLOW flush out the cuttings. You may need to SWAB the hole some (move the head up and down pumping the pipe in and out of the bore to help flush out some large buildup.) You are not digging at that point but the pipe and mud flow helps to get the buildup of cuttings OUT of the hole which will reduce the torque needed. Dropping down close to the bottom but not hitting it is important the flow and increased space taken up by the drill pipe acts like a plunger pumping and moving these cuttings out.
Mark
Thanks Mark,
Makes perfect sense. As a roukie, I tend to hurry and that is no good. A few times I had to draw the pipe up the hole to get flow from the pump---just not enough PSI by my estimate. I understand that PSI is not by istself the end all but without it, flow is nothing. This new pump causes a 21 HP engine to dig in so it has both for the rig needs= flow and PSI?
As I have learned, I need about 70 to 90 GPM for a 6 inch bore hole to keep an up hole flow of about 1 to 1.5 GPM. This pump can provide that at 140 PSI.
I have to monitor my mud better and make sure I have good PH. Got lazy on that=bad outcomes:( I guess, I learn the hard way. Just hard to find people who have information to share on this subject.
Gray
/ Input from the forum? #8
How about some photos.
I will attach a few pictures of some sub assemblies I have worked on and one of the prototype control panel. Feb. 4 I start the first production run attempt with my two man green crew and I:)))) They will be made to order as they are not toys and I can not afford to do anything else but make to order:(
The last design choice I have to make is to use or not use schedule 80 2 inch black pipe for the drill pipe? Many have done so with success but Murphy tends to stay near me:)
Gray
/ Input from the forum? #10
Just stumbled on this....I'm a mud rotary well driller from VA......nice project. Couple of general comments...with good mud, you can overcome a lot of things....carrying cuttings out of the hole is the first job of mud.....get yourself some bentonite and make a good mixer. Flow is key as well.....don't worry about pressure so much...shoot for an uphole velocity of at least 50 feet per minute...so a 6"hole needs 75 gpm flow. You can get by with less with the right mud though. As for pumps, you can drill a 250 - 300' , 8" diameter hole with a $1000 2" trash pump (honda's are the best). Don't ever push when drilling....you should always be holding back the weight of the drill string. You don't need a lot of speed...go for the higher torque motor. What kind of bit are you using? What kind of drill pipe are you using? Are you digging a mud pit or using a pan?
Hello VA Well Driller,
Thanks for your response. I am using a pan--about 150 gal. I will be using a High Torque motor and have float on my hoist so a minimum of down force can be maintained. I had a 2 inch fowmax pump that seamed to not provide enough PIS to keep the flow going but this could have been my roukie mud making actions?????? I switched to a 21 HP MCM Odrill mud pump that can make over 280 ft of head at 150 GPM. It is about a 3000 unit:( The other was about 1500 but it had really good oil bath seals but capped out at 24 PSI for 100 GPM, always seamed to not be able to flow---had to work the pipe after every length to get flow. I have read were some big rigs run hundreds of PSI and GPM for drilling 12 inch holes fown 1000+ ft.
I can keep this mud pump as the manufacturer has allowed me to purchase direct and less than the first pump but I need more HP to drive it. The pumps ability may allow for less issues with buyers?????
I have options of using schedule 80 black pipe or 2 3/8 x 3/16 wall DOM for my drill pipe. My rig may be fine with Schedule 80 black but it is only 30,000 yield VS 70,000 yield with the DOM. Yes, the DOM costs more but then, never should anyone overpower this pipe????????
Anything you can inform me of would be great! I am in an isolated area and have no one of experience to network with on this project.
I have purchased a Marsh vunnle and scale to make sure of my future mud---I feel that is the biggest issue I face.
Thanks and I hope to heard more input.
Gray
/ Input from the forum? #12
Sch80 black pipe is fine...the weak point is the connection, so you'll need to buy some tool joint connections and weld them on. My first rig we bought 2.5" sch 80 black pipe and Mayhew Jr tool joints, worked fine. Now I run 3.5" 0.368 wall rods from Star Iron Works with 2 3/8" IF connections. My rig has a 6000 ftlb tophead, and the most I've ever drilled was a 9 7/8" hole to 900'. We have a lot of loose sand up top, and we regularly drill a 17" hole to 100' to set 10 or 12 " surface casing. I have 3 mud pumps on my rig, a 2" air diaphragm mainly used for pumping cement grout, but you could drill with it. A mission magnum sandmaster 3 x 4 centrifugal with makes up to about 400 gpm and up to about 220psi, and a 5 x 6 Failing piston pump, capable of a constant flow of 180 gpm up to 350 psi. All have their advantages and disadvantages, but fundamentally when you are drilling, the only reason to have a pump to build a lot of pressure, is to overcome the friction loss through the drill pipe. If you are cleaning the hole and not overloading the mud with cuttings, you can literally pour mud in hundreds of feet of drill pipe and it will flow through by gravity. I hate drilling with a pan, and rarely do it if I can help it. You just don't have the volume to settle out and cuttings...you basically will suspend all the cuttings in the mud, then pump off and make up more mud. As for mud, around here, I drill above bedrock, in lots of clay with layers of shells, and gravel. We start with 50lb of bentonite per 300 gal of water, and then add a liquid polymer like WyoVIs from Wyoben or EZmud from Baroid. You should start with marsh funnel of 40 - 45 seconds and don't worry about weight until you start drilling, then start weighing it and try to keep it under 9.5 - 10lb / gallon. That will be hard in your pan, so you'll have to pump off and add water to thin it, but you should always add more bentonite or polymer with adding water to stabilize the hole. How deep are you planning to go? What kind of bit are you using? I use a Mills drag bit for clay, and a long tooth tri cone roller for hard shells and gravel or when I drill a big hole. The Mills bits cut fast, but they can hand a lot and snag, causing lots of torque on the drill rods and the rig. The tri cone sucks for cutting clay, but it will go through tough formations without a lot of torque buildup. I have to switch between the bits sometimes on the same hole.
This is all great information and I do appreciate your sharing it with me.
My pan is two 80 gal low profile tanks interconnected with a baffle near the pick up. You are right about recirculating the cuttings as I tried one pan and got heavy mud from cuttings.
Good to hear that schedule 80 will work as it is the least cost and easiest to get for me.
My pump will flow at 150 GPM at 120 PSI so I think this should allow up to 400 ft on a 6 inch hole?
I will get some of the polymer for my mud mixing-great info!
I am using a GP chevron bit with long reaming flutes and it does have lots of torque needs in rock and heavy gravels.
Anything more would be great and when I am done with the production rig, I will post Pictures?
Thanks again and more is better:)
Gray
/ Input from the forum? #14
100_0565.JPGYou can do that hole easy with that pump, you could cut a 10" hole to 400' with that pump. What size casing? General rule of thumb is to drill a hole twice the size of the casing, or have at least a 2" annulus around the LARGEST OD of the pipe you want to set. Biggest thing people do wrong with mud drilling is go too fast. Drill slow, maybe 2-3' per minute on 6" with your pump, and wait long enough for the cuttings to come back before adding another rod. You may have to wait 20 minutes or even much more on deep to clean the hole, but it's well worth the wait. Build a bigger pan, get up to 300-400 gallons and it will make life much easier. If I loaded the picture right, you will see 2 farm tubs, discharge into the first, which contains most of the cuttings, pickup from the second. There is a connector hose between the two. With a 2 pan setup, you can keep most of the cuttings in the first and have clean mud in the 2nd. This holds about 400 gallons combined.
/ Input from the forum? #15
Too bad you had to drill right next to the potty! Thanks for all the useful info, even if I'm not drilling.
Jim
More great info! Thanks! Yes, I can see the tubs and I am sure more settlement time make good sense. 400 ft is good news even if axtreemly seldom needed.
I will keep this pump I currently have because a change to a lesser pump will not save much and the old pump? It shut down flow at about 34PSI - just no room for any issues.
Nice, clean looking rig you have and looks like huge power on the drive. The rig only gets about 2 ft per hour in hard rock and 5.75 inches? I was drilling through ignious rock on the last job and it was work. Because I am drilling much smaller bore holes, I hope to be able to use less settlement pans? How do you seal the bore hole collar to keep the mud from leaking out? This has caused me trouble.
Just ordered schedule 80 for my drill pipe. Less nervous about until getting your note. Relaxed now, thanks.
Got the last of the supplies on a road trip today! Will be starting the first production build next tuesday.
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
Water Wagon (A64126)
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
