what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #31
Okay, here goes nothing.
I totaled up kilowatt hours and divided that into my total bill for an average cost of $0.28/kwhr. That is what I pay to Hydro One.
   / what on earth does electricity cost near you? #32
Fireplaces are pretty but not very effective.
or very efficient ,once you consider the heat that it puts out is also sucked up the chimney like a vacuum cleaner. one has to consider gasoline / oil for the chain saw, the chainsaw gas or diesel to haul it back to your place, the log splitter, the time you put into it . What other expense comes with using fire wood as a heat source. Is it really cheaper to use, once you figure all the expense ? I have no clue. I cut too much wood as a young lad living at home. Every saturday was fire wood gathering day. No more wood burning as a heat source for me.
   / what on earth does electricity cost near you? #33
my latest bill from APCO is about 11 1/2 cents per kwh. this is in VA. 935 kw for $107.
Im in Central VA and on AEP (taxes, fees, included) our is between 9 and 12 cents per kwh. It seems to vary a little each month..
To the OP - I was in a small 2 bedroom apt and my electric bill for it was more expensive than a house I later moved into. Apts have very little insulation or energy efficient appliances - there is no incentive for the builder/owner to spend pay for better stuff.
Brian
   / what on earth does electricity cost near you? #34
My Dec. bill was 599 dollars,, 9.5 kw,, Christmas lights cost.. most time it's around 300 a month,, but I live on the Texas gulf coast and our AC runs most of the time just because of the humidify.. Lou
   / what on earth does electricity cost near you? #35
A fireplace will suck more heat out of your house than it will put in. Have you ever heated with wood? There's much work involved. Cutting, splitting, hauling, lifting several times.
I think an outside wood burner is the answer if one really wants to get serious about using wood as a heat source. Fireplaces are pretty but not very effective.
My fireplace is pretty and effective. Two 6 inch combustion air inlets from outside and sealed doors. No conditioned air is going up my chimney. Heats 3600 square feet without assistance down to zero degree outside temperature. I built and designed my home to be heated by this unit. Even heat through out house.
I enjoy heating with Firewood. I have a very efficient system for gathering and storing my firewood. I love being in the forest in the winter gathering wood. It keeps my winter fat down too.
Pictured is the back side of my fireplace showing the 6 inch inlets. I was rescueing a bird that day.
http://www.napoleonfireplaces.com/products/nz6000-high-country-wood-burning-fireplace/
I'm still not talking about using firewood as a main heat source. I would really like to use it in my garage for projects and use it in the house to enjoy during cold temperatures as well as burn all the paperwork I acumilate. It would not be the worst back up heat if the fireplace was already in the house I bought. I have grown up with a fireplace as a smaller way to heat the house and enjoy that. I grew up with propane heat and think if I bought a house with propane or natural gas. I would love to use the fireplace in the morning and use it in the event of a power out. It would be a 0.0$ increase in my home if it already had the set up.
I know people to use it as a main source of heat which is a bad choice. Very inefficient and all your time will be spend tending to a fire.
Hope you guys know what I mean
   / what on earth does electricity cost near you? #37
I know quite a few people that burn wood stoves for their main source of heat. Mostly because they have property and a wood source, and time to cut it, and don't have the money to pay a huge electric bill in the winter.
   / what on earth does electricity cost near you? #38
Con Edison of NYC last bill 667 KWHR $195.17 or $0.29 per KWHR. Gas bill for the same period was 175 therms $276.64. :smiley_aafz:
   / what on earth does electricity cost near you? #39
Wow, seeing some of these rates, I guess I feel pretty good about $0.10 KWh! Must be the hydroelectric power source.
   / what on earth does electricity cost near you? #40
Yes in Ontario we are abused by every utility and government no deals here
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
UNUSED FUTURE XJ7T-7T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
2014 Chrysler 300 S Sedan (A55853)
2014 Chrysler 300...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
