John Deere 2305 Compact Tractor Transmission and rear PTO failure
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #91
Does any one have an idea how to replace the rock shaft on the rear pto of A J.D. 2305 or where I can get information on rock shaft replacement . Thank you : Richard
you can go to deereparts.com and see a parts view of the tranny. You can also buy a service manual on disk or paper. It won't be a simple job if I'm thinking correctly. But I have slept since then.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #92
What exactly do you have broken? Is it the shaft that the lift arms attach to or is the housing broke? Do you have pictures?
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #93
As a owner of a 2009 2305, I have reading all the comments about the transmission and rear PTO failure's and the repair cost in most postings at over half the cost of the orginal tractor. While I haven't had a problem (knock on wood) yet, I am just wondering how many 2305's were made and what percentage have experienced rear end failure? Is this problem just unique to the 2305 or do other brands ( kubota, koiti, massy ferguson, and yes even Yanmar's) have the same issues and we just don't hear about them. I worked in the auto industry and I know most suppliers make parts a lot of different companies and just wondering if a lot of the scuts don't use the same rear ends? Just wondering !!!
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #94
Have you read up to know which side of the serial number break your tractor is on? Later transmissions were beefed up.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #95
Welcome to TBN!
No one here will be able to give you firm numbers like you want-and I'm sure JD aint tellin' either!
Good advice.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #96
I did contact my local JD dealer where the tractor was purchased to inquire about the rear end problems. The same dealers owns most of the JD dealerships in Middle Tennessee. He asked for my ID control number and they could tell me when the engine was made, when it was the month tractor was assembled and engine installed and said from the control number 107101 and said my serial number should not have this issue. So I am not sure when the upgrade actually was made but according to what they told me, I would assume the upgrade is sometime before 2/19/2009. I hope this helps other member. I would still like to know if this was a problem unique to the JD 2305 or did other brands of tractors use this same tuff touque rear end and have the same issues?
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #97
Pretty sure that myself or somebody posted the serial number split here on this very topic.
If you look here, you can find the split. I hesitate to spoon feed people at actual number without them working a little for it.
John Deere - Parts Catalog
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #98
Iirc it was around august 2007. Mine was an "upgraded" 2008 when it failed. All things, all brands have quirks, some minor, some major. This one is major.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #99
"Quirk"? yelbike, you're being a little too kind. A $5600 repair is a bit more than a quirk, even a major quirk.
Is it safe to say that when I had this repair done in Aug 2010 they used upgraded parts? I still am much more careful with my tractor than I was in the beginning. I thought I had a work horse but now I baby the PTO quite a bit. Maybe that's a good rule of thumb anyway.
Nearly 4 years later I'm still mad about this issue and JD's refusal to offer ANY assistance.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #100
No manufacture would be in business if they warranty repaired every broken item on a 5yr old machine used by who knows where and how.
There was a link one time to an abusive operator of a 2305 on U-tube yanking tree out. He had a long chain and would take a top speed run to yank again and again until the tree roots gave. I'm sure he would be all hissy at JD when he smashes something.
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
