It's Cold !
   / It's Cold ! #181
First winter the ScanGauge II in my truck has seen this kind of cold.
Fired it up this morning, Trans Temp was reading 8190 Deg F.
The factory computer understood it, but the Scangauge really got confused by the data it was seeing at first. After a couple of minutes running, it started reading in the low single digits F.
It's cold enough that the Bytes are freezing their Bits Off ! :cold::cold::cold:
Rgds, D.
   / It's Cold ! #182
-38 degrees Celcius here in eastern Ontario
Good thing we have plenty of wood to burn !
BLACK
   / It's Cold ! #183
Twenty below F this morning up on the hill. I'm sure down in the village its worse. Time to throw on some special reserve rock maple and let her roar.
   / It's Cold ! #184
0 here Kioti started right up, as soon as he warms up I will be pushing snow, just did the conversion -38C = -36.4F hey Black you could warm up a bit by using F
   / It's Cold ! #185
-24 Up here on the other side of the pond. Everything turned over hard this morning, even the old lady!
Sent from my LGL35G using TractorByNet
   / It's Cold ! #186
I've always had an affinity for -40 as it is the same for both Fahrenheit and Celsius.
   / It's Cold ! #188
-16 and all is quiet
   / It's Cold ! #189
-6 and the sun is out
and no wind
   / It's Cold ! #190
Dang heat wave here in NC @ 21...
But it does feel like 14 according to Weather Channel...LOL
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
Tallman Water Pump (A50774)
Tallman Water Pump...
HOWSE 67" BOX BLADE W/ SCARFIER (A51243)
HOWSE 67" BOX...
(INOP) 2001 KOMATSU WA250-3MC WHEEL LOADER (A51242)
(INOP) 2001...
10' Feed Bunk (A50515)
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
