TL 100A
   / TL 100A #11
I just purchased a used 2007 TL100A tractor, 4WD, Cab, 830TL Loader. It has 12/12 Transmission. Any advice, tips, tricks or suggestions would be appreciated.
David;
We have same tractor, bought new, in late 2007. Ours has a Bush Hog 5045 FEL which is as size larger than installed on most TL100A's, primarily to get added lift capacity and lift height. Primary use is to operate BH cutter and an 84" grapple to clear dead trees. The TL100A is a very capable tractor and has a lot of power. I assume yours is 4 WD? Ours has cab and HVAC which is a real blessing during hot Texas summers. Actually got to use the heater last weekend and over the holidays. Let us know if you need additional info.
Clue #1- Add ballast to rear tires if not already done. Makes big difference in traction.
Clue #2- If you need a grapple get the W.R. Long 3rd function kit. If you have the NH mid mount valve set for a FEL adding the WRL is a piece of cake. Use skid steer flat face QD connectors at front of your tractor.
Clue #3 - get a good quality CAT 2 quick attach for your 3 point.
We also have a Kubota B2710 HST for small work.
   / TL 100A
Thanks for the reply Rick. It does have ballast in the rear tires. Appreciate the suggestions for the 3 point hitch and grapple.
   / TL 100A #13
David;
While doing your maintenance don't forget the cab air filters, one on each side underneath the overhang of the cab top. Did you get a ops manual with your TL?
   / TL 100A
Great point. I had not thought about those filters. I do have an Operating Manual
   / TL 100A #15
The TL90A is identical to the TL100A except for a turn of the screw on the injector pump, so .......anyone with the tl90a with a needed fix is worth while looking to. And vice versa too.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAHP71W77X101435 (A57453)
2007 Ford Crown...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
