John Deere 2120 Pressure Relief Valve Location
   / John Deere 2120 Pressure Relief Valve Location #12
Can't dead head the pump. It's a variable stoke closed Center eight piston radial pump.
May I ask you to clarify your statement?
bigblock76 can plug a 3000 # gauge in rear breakaway coupler and hyd oil will be dead headed into gauge which will be stand-by pressure..
   / John Deere 2120 Pressure Relief Valve Location #13
The pump can be dead headed , won't burst a component and doesn't need a relief valve. A positive displacement fixed flow pump if dead headed will stall or break something.
   / John Deere 2120 Pressure Relief Valve Location #14
I thought you stated earlier it couldn't be dead headed????? I hope you make better decisions at your Nuclear JOB !!!!
#19 2nd photo is the adjustment screw for SC valve
Ok thanks. Looks like that should be easily accessible from underneath the tractor. Can it be done with the engine running or best when its off?
Mark
   / John Deere 2120 Pressure Relief Valve Location #16
Yes it can be adjusted with engine running.
   / John Deere 2120 Pressure Relief Valve Location #17
My 2120 JD has a power steering issue. Power steering will stop working after about 30 minutes. Let tractor sit for about 5 minutes and it starts working again for a while. Any suggestions on causes and solutions? Thanks
   / John Deere 2120 Pressure Relief Valve Location #18
emazu5
Welcome to TBN
Update us on the history of hyd oil changes and filter change.
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1992 AM General...
19015 (A53422)
19015 (A53422)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
