How to clean the dirt and old grease around FEL pins?
   / How to clean the dirt and old grease around FEL pins? #1
jodebg
New Hartford, CT
Kubota B-2650
Recently purchased a 10 year old Kubota B7800.
I am in the process of cleaning the tractor and now
need to clean the areas around all of the FEL grease fittings.
What is the best/do-no-harm approach? What should I use-
a degreaser, brush, garden hose, power washer, etc.?
Will a power washer push dirt and grit into areas where it should not be?
Thanks for your help.
   / How to clean the dirt and old grease around FEL pins? #2
If it was mine, I would use some WD40 on a rag, wipe it up, and push in some new grease. If the grease goes in good, go on. If you can't get it in the grease channel, pull the pins one at a time with bucket relaxed on the ground, and clean up the grease channel, and reinsert and grease. Clean it once in a while with the WD40 soaked rag. At least that is what I would do. Everyone to their own pleasure.:)
   / How to clean the dirt and old grease around FEL pins? #3
Diesel or WD-40 on a rag if you want to get them real clean. For periodic 10-hr greasing, I simply use an old paint brush to pick up the gobs of old grease and dirt that get pushed out, and scrape it on a piece of cardboard.
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
1305 (A58374)
1305 (A58374)
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2016 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2016 Freightliner...
2018 Ford F-350 Flatbed Truck (A55973)
2018 Ford F-350...
