John Deere 2120 Pressure Relief Valve Location
   / John Deere 2120 Pressure Relief Valve Location #1
bigblock76
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Hello,
Does anyone know where this is located on the tractor? Reason being is that I suspect it to be failing as I'm starting to have a hard time lifting bales with the JD 175 loader that is attached to it. Fluids were changed in the fall, filter and screen was all taken apart by myself and there wasn't much of anything that came from the screen.
I heard about shim kits? But will need to test out the pressure before tweaking.
Mark
   / John Deere 2120 Pressure Relief Valve Location #2
I doubt very seriously that your tractors pressure relief valve is the problem for your tractors inability to raise a rd bale on the FEL but here's a parts photo of the valve. It's on the RH side of trans case behind the hyd filter. HAVE YOU CHECKED STAND-BY pressure? It should be 2250 but 2350 is better.
Hi Tx Jim, Thanks for responding!
I am going to build a gauge this week to test. Is the best place to test off the pump or using the rear remote?
I thought that part on the tractor was to ensure that the tractor always had power steering when using other attachments with how the fluid would flow in priority? With that said, maybe we are on to something else as I notice sometimes if I'm standing still using the loader and I try to turn the steering wheel its as if I don't have any power steering. Its super hard. And as soon as I start to move I get my power steering back. Using the loader sometimes, and I mean maybe happens 10 times a year, jerks the steering wheel around so maybe this part you are showing me needs a rebuild and not a shim kit?
Mark
   / John Deere 2120 Pressure Relief Valve Location #4
1st thing to do is check stand-by pressure. Checking at remote breakaway will be fine. You'd be surprised how much an extra 100 #s of stand-by pressure will help operation of FEL.
So just plug it into the quick connect fitting and move the SCV to dead head the pump?
Forgot to also ask, if the pressure is lower than lets say 2000lbs on stand by, what else do I need to investigate? I ask ahead of time since my tractor is 1hr away from me on my farm, so I'd like to try as much as I can while I'm there and report back to you.
   / John Deere 2120 Pressure Relief Valve Location #8
Forgot to also ask, if the pressure is lower than lets say 2000lbs on stand by, what else do I need to investigate? .
If stand-by pressure is low try "screwing in" stroke control valve adjusting screw on the frt pump
Hi Tx Jim; Which number on either of these diagrams is the adjustment screw to turn if that's what I need to do? This weekend won't be too cold so I'm hoping I can get to it then.
   / John Deere 2120 Pressure Relief Valve Location #10
#19 2nd photo is the adjustment screw for SC valve
2018 John Deere Z997R (A53317)
2018 John Deere...
2019 TerraGator 7300 Spinner truck (A55314)
2019 TerraGator...
2018 John Deere TX (A53317)
2018 John Deere TX...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55314)
BOSS 990 Fuel...
2025 Kivel Bale Spear Skid Steer Attachment (A55851)
2025 Kivel Bale...
