JD 2210 Red fluid in the snow
   / JD 2210 Red fluid in the snow #1
nfernandez
Byron Center, MI
John Deere 2210
I have a John Deere 2210 that I got this past fall. I started using it this winter for snow plowing with the FEL and it works great. I just started noticing a red/pink fluid in the snow if I let it sit for a bit while running. I looked in the rear of the tractor and found the transmission oil window was showing low. I added more but I am wondering where the leak would be coming from? I the area around the rear PTO is saturated in the red/pink fluid, almost as if it was sprayed. I wiped it all down and plowed again and found it there again, the entire area around the rear PTO was saturated.
I read that there's a "vent" for the transmission that could get clogged and cause it to spray out air/oil when it gets hot. Does anyone have experience with this? If so, where is the vent so I can see if its dirty or snow covered?
   / JD 2210 Red fluid in the snow #2
I have a first-year 2210 (MY2003) and at about the six month point it started to leak where the 3 point hitch top link attaches to the back of the transmission housing. In my case the dealer removed and resealed the mounting bracket that bolts to the case - it's a fairly large, square, cast piece with 4 bolts as I recall. Mine has not leaked any more but I do get a little seepage around the seal. I would start there. That is the only common leak on the 2210 that I have ever heard about.
You might also check your quick connect fittings where the loader hoses attach to the joystick.
BTW I found with mine that the leak only occurred when I was using the 3 point, when you raise it all the way up it makes contact inside the case. When I didn't use the 3 point I didn't get much leakage. So if you're only using a loader and not blade on the 3 point I would look over all the loader connections first.
Good luck!
Good luck!
Thanks for the info. I will look over some of the connections to see if I can find anything. If it is the mounting bracket (which is where i would say its leaking from if I had to guess), is that something I can order a gasket for and reseal myself? Or is that a dealer only type of task? I try to do as much as I can myself to save some money. I have some experience with lawnmowers and such so if its something people can do in their garage, I probably can pull it off.
Thanks
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
TOOL BOX (A50854)
TOOL BOX (A50854)
WARREN POWER SYSTEMS  100KW GENERATOR (A50854)
WARREN POWER...
1268 (A50490)
1268 (A50490)
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
