Texas Fall/Winter thread!
/ Texas Fall/Winter thread! #4,301
Our official temperature is 11 and the TV news is running a banner across the bottom of the screen saying an energy emergency has been declared and for us to cut back on electricity usage to avoid rolling blackouts. I'm sure a lot of people get up and go to work without seeing the news, and then as businesses open for the day, I assume energy use goes up. So we're hoping we don't have a power outage.
/ Texas Fall/Winter thread! #4,302
Well, I dragged my lazy hide out of bed just before 8 AM this morning and my temperature gage says 10 F. Blueriver has me beat, but I'd expect that with him being from the Oklahoma Tundra.:D My Bowie airport weather station is having problems and not reporting properly or I could just go there and look at the series of overnight temperatures. Their current temperature is 12 F. You look outside here and it looks clear and warm with the sun shining brightly, but I know better.:)
FG, I'm with you. I'll take summer over winter any day. My body just does not understand cold.
/ Texas Fall/Winter thread! #4,303
Will have to wait until I get back home to try a Potbelly. There is one near my home. Ann Arbor has 3. Must be a college town thing.
I guess it is a college thing. There are 4 or 5, maybe 6 Jimmy Johns around the UT campus. They have bicycle delivery people.
hugs, Brandi
/ Texas Fall/Winter thread! #4,304
Going to the beach today,, so I can surf the waves,, When we get a strong north wind like this the surf is calm.. the water is flat,, That's the only time I can stand on a surf board without falling over,, As long as it's on the sand not the water.. surfside here I come.. going to eat at the purple cow the crowds this time of year is small.. like one every five miles of beach.,:laughing:, Lou
/ Texas Fall/Winter thread! #4,305
My grandson just told me that our downstairs bathroom is frozen up (lavatory and commode). The tub still runs, but it has no pipes on the outside north wall like the lav and commode. I put some vents into the wall so warm air could go in, but I need to finish the job by cutting holes and installing grills up high so warm air can move up inside the wall with convection current. Luckily, the pipes are PEX, so there is little danger of freezing and bursting. I don't want a repeat performance of my flooded basement from a few years ago. The only thing I really worry about is the PEX fittings (unions and 90 degree Ls) that could be pushed apart by ice in the pipes. We really don't build well for cold weather here.
/ Texas Fall/Winter thread! #4,306
If your lavatory is in a cabinet open the cabinet doors and leave them open. Leave the bathroom door open as well, unless you have guests. :laughing:That sometimes makes the difference
with pipes in outside walls.
How low can the temperature go outside before your heating system can't maintain normal temperature in your house?
/ Texas Fall/Winter thread! #4,307
Don,
Glad your better. Elgin doesn't have 24/7 emergency room?
I was in Austin and Kyle yesterday. I helped move my daughter in with a friend that was also an ex room mate. She has a 3 bedroom house down in Kyle. The no good fiancee didn't want to get married. They had to move out anyway, as Rebecca's other friend is coming home from deployment and will move back into the house Rebecca was renting for a song.
I sure pray Rebecca learned her lesson. Now, new room mate is letting her stay 6 months to get on her feet. So we got six months breathing room, if Rebecca can manage a new baby and an hour work commute.
Now, to help her might jeopardize my retirement plans. Best plan would be to do my retirement plans and include her and my Grand daughter. That would entail me moving retirement plan property closer to north Austin, (she works for the state near I-35 and 290) or her commuting a distance, like she will do now from Kyle. I wanted to be within an hour of her in retirement. She is fixin' to file for child support. They parted with a good friendship, so we will see. He works for the state, so getting child support should be easy. But I am still holding my breath.
On a happier note....My Big RED Beast will be paid off April Fools Day.
Thanks for letting me vent.
hugs, Brandi
Sorry for your drama. Hope it all works out for your daughter. Does your company have any operations/jobs you could transfer to ABIA? Or can your daughter transfer near you?
/ Texas Fall/Winter thread! #4,308
Jim,
Here I was thinking about buying property in Wise county TX to be warm in the winter and I'm warmer than you
you are, at least till this evening.
FG says you measure distance in time rather than miles. Very comparable weather right now considering that I'm
38 minutes north of you in Latitude at mach 1. :confused3:
/ Texas Fall/Winter thread! #4,309
Ron, we not only leave our lav doors open, but also put a small space heater in front of the opening to provide heat. The pipes run through the ceiling and drop down the wall. I believe the freeze is happening between the upper header plate and the sink as the pipes drop down the inside of the wall.
My house has no problem maintaining heat in the bathroom. We even have a supplemental heat-pump unit mounted in the wall that can easily put the room temperature up at 80+ degrees. The trouble is that heat is not making it inside the wall. I just need to open up wall vent holes and cover them with nice louvered plates I have purchased.
/ Texas Fall/Winter thread! #4,310
Kyle,
I gather you are referring to the new Austin airport/old Air Force base. I don't know the airport 3 letter identifer is for that airport. Old Austin airport was AUS. It might be the new one also. I need to check.
I could transfer to a lot of positions there, if I wanted to cut my pay about in half and loose all my weekend off senority. Also, it could be up to a year or more before an opening was available. I would wind up with Tuesday and Wednesdays off. I could transfer, if there is an opening, to ground equipment, for a 4 dollar pay cut, and work on tugs or such,......... just like an auto mechanic. Again, if an opening was vacate. I never have considered any of these options and do not want to. I would keep my vacation senority, but everything else would be like a new hire.
hugs, Brandi
/ Texas Fall/Winter thread! #4,311
Yes, Mueller was AUS. I think Austin/Bergstrom is AUS now too, but like you, I'd need to look. I will before I need to know, but not on the top of my "to do" list, tonight.
Lou; you surf like I do! And even on the sand, I might not stay up on the board! At least with really thin crowds, no one sees when I fall! :D
jinman; I hope when things thaw out, you find the frozen pipes intact, with no leaks.
pacerron; With the brunt of winter hitting you tonight, y'all stay safe and warm.
I froze all day. Managed to get down to 8* before things began that "warm up" for the day. My hands are still not feeling normal, even after being indoors a while and a hot shower. Just tingly, but nothing serious. Another really cold one in the morning, although not predicted to be as bad. I hear just down to 17! :shocked: No more below freezing temps after that, for at least a week, if weather guessers are correct.
Just poured myself a cup of hot cocoa. Hate to spare the calories, but it sure is good going down. How long until it is warm enough to pick up the hoe and think about planting for the Spring/Summer garden? I'm ready! I'll be glad to say "goodbye winter"!
/ Texas Fall/Winter thread! #4,312
Austin-Bergstrom International is AUS.
/ Texas Fall/Winter thread! #4,313
I know officially it is AUS, but the locals call it ABIA.
Still cold. Brandi, AUS is in a valley and it usually runs almost 10 - 14 degrees colder than Austin's official temps. So, it is almost always cold there in the winter mornings...recommend an inside hangar job. Traffic is just as bad in Austin as it is in Houston. You can almost always expect delays.
/ Texas Fall/Winter thread! #4,314
Jim, sure hope you do not get another flood. Our master bathroom has ceiling pipes feeding it. I always worry about pipes freezing. Installed taps that allow blowing out the lines. When it gets real cold outside.
/ Texas Fall/Winter thread! #4,315
Yahoo !!! Heat wave ... Almost 2X as warm as yesterday morning ... 17 and headed to the fortys
/ Texas Fall/Winter thread! #4,316
Break out the shorts and tank top!!!
14 here, but once it gets above freezing, should stay above for a spell. Guessers are calling for rain beginning Thursday night, thru possibly Saturday. I won't complain, if temps stay above freezing. This has sure been a crazy late Fall, and winter, so far!
The first one of you that complains about the heat, this summer, will be on my "poop list"!
/ Texas Fall/Winter thread! #4,318
It will take a few days for my body to get ready for 80° on Friday. Is that complaining? :rolleyes:
Yep, you're going to have to turn muffin around, take a picture and change your avatar.:D
/ Texas Fall/Winter thread! #4,319
Kyle,
Uh..........we don't have a hangar at AUS. Mechanics from HOU cover AUS. Sometimes in a rented Learjet........mostly by van. If we need hangar space in AUS, we rent it for the day or night. I-35 is always inbumper to bumper. I stay off of it.
I have a job I can retire on on the crew I am on now. Now, no more transfer talk.
hugs, Brandi
/ Texas Fall/Winter thread! #4,320
Now FG, don't go out back to poop and let the hogs eat ya! We were all toasty in our heated hangar last night. When we finished our first plane and parked it outside....someone had to stay on board and monitor the APU and turn the packs on heat if needed....to keep everything nice and ready and not cold soaked. It was a busy night for line mechanics across the country last night. Not much sleepin' time.
hugs, Brandi
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
