It's Cold !
   / It's Cold ! #101
If it is getting that cold you must be on the wrong half of the world, we only get down to 17. :thumbsup:
   / It's Cold ! #102
Well they don't get frost bite but when it's running the wind chill will effect how much heat is being lost. This will show up in how hard your cab heater needs to work to keep the glass clear. Also when you shut it down if it is in the wind it will cool down to the ambient temp quicker then if it is some place that is calm. That might effect how long it takes for your fuel tank to jell up. Once it is shut off and down to the ambient temp. Then wind chill will not affect it. Your house also looses heat faster in a wind. It痴 just a matter of the temperature difference of the surface and the air passing over it.
Bingo!
   / It's Cold ! #105
Our governor closed all public schools in Minnesota for Monday!
Just because it might get as cold in the Twin Cities for one or two days as we get on a regular basis up north, the entire state gets in a tizzy. Metro wimps. Meanwhile, the rest of us will go to work as usual.
Joe
   / It's Cold ! #106
Absoluteley . Any kind of block heater etc is far less effective with a high windchill , Even just to shelter a machine behind a bale stack or trees helps . It may not make sense on paper but come and start our CATS out in the bush in -30 they will tell you different :)
That's a good point. If your trying to keep it warm with a block heater and the wind if it is below zero can strip out all the heat that the heater produces. That's why covering my tractor in tarps the other day helped get it started. The Mr. heat on a 20 lb. propane bottle inside the tarps helped a lot also. :eek:
   / It's Cold ! #107
10* here this morning & windy, only going down today. :thumbdown: Supposed to stay below zero until sometime Tuesday! :eek: I'll clear the walk to the shop & add wood to the fire, may not get out much until Tuesday afternoon. The advantages of being retired!!! :D ~~ grnspot
   / It's Cold !
Be sure to bring your pets inside tonight.
   / It's Cold ! #109
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
1967 Minneapolis- Moline M670 (A50514)
1967 Minneapolis-...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
