Testing a block heater
/ Testing a block heater #1
Pipestone Kid
Gold Member
Bigfork, Mn.
JD 4110HST
I have a 2004 JD 4110 with a JD block heater. Is there a test I can do to see if it is working? This morning I had it on for about an hour and a half. When I went to start it, it turned over rather slow, but started OK. Of course, one other possibility is the battery is getting tired--it is the original battery. Any feedback is welcomed. Thanks, Jim
P.S. It was zero degrees but in a garage.
/ Testing a block heater #2
if you have a clap on meter, you can do an amp test on one leg of the circuit. see if theres a draw. you cant just clamp it around the entire cord, you need to do it around only one wire (black) of the 120 volt circuit.
/ Testing a block heater #3
Cord should get warm to the touch. Make sure the extension cord it's on is a decent gauge and not too long.
/ Testing a block heater #4
Easiest way to test them is to plug them in to a known power source. Every one I have ever owned or used that was functional got hot to the touch within seconds.
/ Testing a block heater #5
but you have to remove it from block to test it this way. A meter can test it while installed.
/ Testing a block heater #7
What?????? Plug it in, touch it, how much easier can it be? No removal necessary, no meter necessary. They either work or they don't.
?? my block heater on the JD870 didnt get hot to the touch at all. Maybe im thinking of something else than what your talking about. I cant even reach the ones on my trucks...there buried up underneath everything else.
The only way i knew my old JD was working was the tractor started up easier with it plugged in.
/ Testing a block heater #8
The OP has a tractor. Coolant heaters I have owned were installed in tractors, with one exception. Generally you can walk up to a block heater in a tractor and touch it, sometimes after opening a hood or removing a side panel. I can't imagine a functioning block heater on a Deere 870 or anything else for that matter that didn't get warm to the touch. By definition they make heat. It's kind of amazing to even be involved in a discussion of this nature. I've been using coolant heaters in diesel tractors for the past 40 plus years. It's not new technology, or something I'm guessing about.
/ Testing a block heater #9
The OP has a tractor. Coolant heaters I have owned were installed in tractors, with one exception. Generally you can walk up to them and touch them, sometimes after opening a hood or removing a side panel. I can't imagine a functioning block heater on a Deere 870 or anything else for that matter that didn't get warm to the touch. By definition they make heat.
My 870 had it in a freeze plug somewheres on the engine...dont remember where. There was a plug that ran down and was zipped tied next to the starter. thats all i remember about it. Whenever i want to know if something electrical is working, i use a clamp on meter. a can get a reading and know in a matter of seconds how many watts its pulling. Been an electrician for 30 years. Old habits are hard to break
/ Testing a block heater #10
a good 'combo' to go with a block heater is a trickle charger on t he battery.
have a timer setup to turn the block heater and the trickle charger on. additionally.. a mag heater on the oil pan and the hydro pan will help.. that way you have warmed coolant.. engine oil.. and hydro oil.. plus a topped off and warmed battery. that's a magic combo for good starting in cold weather for a diesel.
/ Testing a block heater #11
That for sure will work, but you still have to split the legs, don't you, say if you have an old analog Amprobe like mine?
/ Testing a block heater #12
i have a test block i use, has a male and female end with open wires to place the clamp. like i said, im an electrician and have to deal with loads and current on a daily basis. For anyone else, yes the leads must be separate. test hot leg only.
/ Testing a block heater #13
I can see how that test block would be a very useful item.
I don't have a clamp on meter, so I can't try that--even if I did, the cord on the heater is moulded and would be very difficult to split. I will try "feeling it to see if it gets warm (I can get at it easily). Sound guy- I have a magnetic heater, but I don't know what kind of alloy the pan is, but a magnet will not stick to it. I have a remote set up for the power so I can turn it on and off from the house. (also have a light hooked up to the remote so I can tell if it is on)The extension cord is a 25 foot with #12 wire, so that isn't holding anything back. I will do some more checking and report back.
/ Testing a block heater #15
When I plug in my block heater, I can hear it sizzle, , I know it is working, , can also feel the block but don't have to if I can hear it.
/ Testing a block heater #16
sounds like a cast aluminum pan.
if you have a meter , ohm out the heating element. it will be low.. but not a short. figure 9-11 ohms 'or so' for say.. a 1500w element...
Thanks Sound guy--I have a meter,but I won't be checking it for at least a few hours. We have 31 below zero and a wind chill of 44 below, so I think I will sit by the fire for a little longer........
/ Testing a block heater #18
An infrared heat gun will show the temperature of the engine block rising above the ambient temperature, if its working. You can get them at Harbor Freight for about $30 bucks and they are great for checking woodstove temperatures and other things.
/ Testing a block heater #19
Another great inexpensive tool whose uses are limited only by the imagination of the owner. Available at HF and many other retailers.
/ Testing a block heater #20
I have never seen a block heater where the engine wasn't warm to the touch after a period of time, usually quite quickly. Most I can hear sizzling immediately!
If it appears to be not working, putting on a clamp-on amp meter is a moot point! I use this for purposes of telling what a heater draws for interest sake. I have a plug and a recepticle with six inches of single conductor wire between them to use the clamp-on meter.
But back to the problem. If it isn't working, it's either a defective cord, or a heater element burned open. Sometimes the heater connections arc, destroying the contacts. You can test the cord with an ohm meter. One side at a time, from plug to socket. If that is good (and it might be intermittent, broken on the inside from flexing or heat) plugging it into the heater, should give you a reading accross your 110 plug, showing the element resistance, some fairly low ohms reading. Wattage = 110 X Current in amps. Amps = 110 / resistance in ohms.
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
2012 Ford Transit Connect Passenger Van (A61568)
2012 Ford Transit...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A61165)
2011 Dodge Charger...
KUBOTA BRUSHGUARD PART (A62130)
KUBOTA BRUSHGUARD...
