L3700SU pushing show with 8 foot blade!
   / L3700SU pushing show with 8 foot blade! #1
stoyan79
Gold Member
Kubota L3700SU, TYM 4820CH
When I originally put this setup together, I thought the L3700SU is not big enough to push 8 foot blade, guess what, I was wrong.
Tractor is totally stock, R4 tires, no extra weights!
Don't even have to shift in low, didn't use the locking diff either!
It is unstoppable, it even pushes the small mountain of snow I created today.
   / L3700SU pushing show with 8 foot blade! #2
Like the setup.
With plow extended so far hows rear traction w/no extra ballast..wonder how pushing heavy wet snow.
   / L3700SU pushing show with 8 foot blade! #3
I recommend putting rear ballast on to relieve some of the weight on the front axle when blade is only being supported by the loader arms.
I run a 7 foot Western on my B2400. I need chains and rear ballast. For rear ballast I use a 5 foot box blade. There is a significant difference in the handling with rear ballast. I can tell that there is less stress on the front axle.
BTW, Nice job.
   / L3700SU pushing show with 8 foot blade! #4
Not to pee on your snow pushing job, it looks like your tractor did a great job, but your land looks to be flat as a pancake. Down here in the hills, it is often a big struggle to get the tractor up a hill at all without chains, let alone try to push snow. Also different snows push a lot differently. Dry vs wet for instance. Again no disrespect meant.
We have no hills in Indiana :)
I think if this tractor was a girl, I will be cheating on my wife right about now :thumbsup:
Is this normal?
   / L3700SU pushing show with 8 foot blade! #6
Is this normal?
Well you gotta remember when you "snuggle" with your 'bota she has a mighty cold heart this time of year.:)
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
