Mahindra 3215 HST
   / Mahindra 3215 HST #1
Mahindra guy
Newport, WA
Mahindra 3215 HST
The 3215 I use clicks when I turn the ignition key. On the third try it usually starts. Should I try to replace the solenoid or just live with the problem. Thanks, Mahindra Guy
   / Mahindra 3215 HST #2
I am assuming you are giving time for the glow plugs to reach temp, before starting? I also have a 3215 and it clicks as the glow plugs are warming.
   / Mahindra 3215 HST #3
If the glow plugs are energized they draw a lot of power from the battery. If you try to crank it over before the plugs shut off the battery may not be up to the task. How old is the battery?
Or it could be a ground connection problem.
   / Mahindra 3215 HST
Thank you for you reply, I will wait longer to try and start the machine, but will also clean all the connections from the battery. Where can I get a service manual for 3215? Mahindra guy
   / Mahindra 3215 HST
Thank you for your reply. The battery is new, but believe after much research that the battery connections and ground may be slightly corroded. I have an volt meter and will check for voltage drop at the starter. Do you know a web sit that I can get a shop manual for the tractor?:)
   / Mahindra 3215 HST #6
I lucked out getting parts and service manuals for mine from another TBN member who new a dealer that went out of business several years ago. I think he said all the manuals that dealer had are gone. Unless you can find one on Ebay or CL you'll have to order it from your dealer if they are still available. Or ask one of the dealers on this site via a private message.
Is this a new to you tractor or have you had it a while?
Mine clicks when the key is turned on but the only noise I hear is the fuel pump clicking. Is your clicking coming from the pump or the starter when you turn the key?
The glow plug light on the dash stays lit for about 10 seconds. When it goes off then I can turn the key to start.
   / Mahindra 3215 HST
The 3215 is a 2008 and the clicking was caused loose solenoid connections. The problem is evidently solved. Thank you all. Happy New Year:cool2:
   / Mahindra 3215 HST #8
I have a 2012 3016 that does the same thing occasionally if you mean by "clicking" that sound you get when you turn the key and get what sounds like a vibrato set of electrical snaps of a weak battery. I'll have to check my starter solenoid.
   / Mahindra 3215 HST
I'd check the battery connections, but the small wires from the ignition switch were loose on my 3215. Other post's recommend letting the glow plugs warm up longer, but you most likely know that already. The sound is the solenoid trying to engage, but fails to connect. Happy new year.
About what does a 3016 cost these days?
   / Mahindra 3215 HST #10
These days i'm not sure. I paid 17K for mine otd -loaded tires this past Oct. (2012 left over…I guess few people want a geared tractor) I heard they may be 2 grand more now a days.
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
