JOHN DEERE 110 TLB Problem with power steering lines / hoses
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #1
DocDryden
Gold Member
Lapeer County
JD 110 TLB
After giving my 110 a look-over, I notice that the power steering lines have some worn spots from rubbing one another. (I can see the steel reinforcement inside). My question is are they ready to start leaking at anytime? Do you think I should replace them soon? I tried to reposition them so that they won't touch anything but no matter what I do they still rub on one another. Maybe they were replaced with the wrong lines (sometime ago). Is this a problem that other 110 owners are having?
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #2
I doubt they will leak anytime soon but because the steel braid is exposed it will tend to rust and weaken over time. That being said I have had line that looked like yours that lasted years. One way to stop the rubbing is to cut a piece of old inner tube and wrap the lines so they rub the inner tube rather than each other.
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #3
They will last a while longer, maybe replace them at the next major service while its down anyway.
Thanks for the tip. I will try to get an inner tube on the lines asap.
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #5
An inner tube does not sound durable at all. I think it would where out quicker than the hose did.
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #6
It is quit durable. I have had it last a long time. The idea is to keep the hoses from wearing anymore.
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #7
I like to split heater hose and use nylon ties to secure for chafe protection.
Thanks for the tip with the split heater hose.
I replaced the power steering lines. The old power steering lines were worse than I thought.
   / JOHN DEERE 110 TLB Problem with power steering lines / hoses #9
Two things seem to take out hoses... age/exposure and abrasion.
Covering one hose with another helps with both.
One of my first jobs was running pneumatic tubing and hydraulic lines for on the machines handling the solid rocket fuel used for the Space Shuttle.
The regular guy happened to be on vacation when the inspector came into the plant and told the boss he liked my work... from that day on one of my jobs was to plumb the rocket fuel mixer/dumpers.
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A55218)
2018 Link-Belt LBX...
UNUSED FUTURE M48 - 48" HYD MIXING BUCKET (A54757)
UNUSED FUTURE M48...
2002 PITTS 102" X 35' LOWBOY TRAILER (A51406)
2002 PITTS 102" X...
UNUSED FUTURE 40" MINI LAND LEVELER (A54757)
UNUSED FUTURE 40"...
