Bought this flail mower
/ Bought this flail mower #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I recently found a flail mower for sale. I posted a thread with pictures asking for information. I only got one response from Halftrack identifying it as a Ford 917. I decided to go ahead and take a chance and bought it. There is an identification number cast on the gearbox cover. It looks like 202299. Is that the model number? Any information you can give me on this mower will be appreciated.
/ Bought this flail mower #2
I have one like it with 33 cutting stations between 74 & 78" wide.
It cuts must of what a bushhog will and also will cut a yard just like a mower.
I have a IH 424 diesel tractor with about 35 pto HP and it pulls it fine unless I'm in 3' tall grass.
Parts are avalible from New Holland and Flail Master.
/ Bought this flail mower #3
My Ford has a 1.5 x 2.5 Alum. tag on it serial and model no. on it.
I can't find a alum tag on mine. Only the number that is cast on the gearbox. Any help identifying the model of this mower is appreciated.
/ Bought this flail mower #5
I think that may be the part number of the cover. Here are some pictures of a 917A, from a google image search.
https://www.google.com/search?safe=...Mower-Tractor-3-point-attachment.html;350;263
I noticed that you are the guy that started the mother of flail mower threads, "Let's talk flail mowers", back in 2008.
How many have you had since then?
LEONZ must be on vacation.
:laughing:
/ Bought this flail mower #6
:laughing:
That is a really good threads, I spent almost a whole day to read it, to see how US customers think about flail mower.
Great thread, thank you.
View attachment 350922View attachment 350923 View attachment 350924 View attachment 350925 View attachment 350926
:laughing:
Yes I am the one that started that thread. Never got one back then and basically dropped out of that thread but it definitely is an epic. Just got a flail this week. I may be the only person to start a flail thread and not get a " welcome to the flail nation" from Leonz. Kinda feel slighted. Wonder where Mr Z is?
/ Bought this flail mower #8
I saw the photos after responding to your IM. Not sure, I'd have to see a side view of a lower three point lift receiver. If there are not small holes above and below the actual lift pin holes, your can rule out 917H. Having said that, hopefully the parts diagrams can narrow it down to a 917 or a 917A or a 917L
//greg//
//greg//
Thanks Greg. No small holes in the lower 3 point lift receiver. I'm sure it's not 917h.
One other thing, I plan on replacing the belt. Where is the best place, as in least expensive place, to buy a quality belt? Can I just take the old belt into a Napa, or similar and get them to match, or do I need a specific belt number or model number of the flail to get the correct belt?
/ Bought this flail mower #10
Greetings TNhobby farmer from my corner of the soon to be
frozen Eastern Wilderness @1140 feet above mean sea level.
I want to welcome you as the newest member of the Flail Mower Nation.
You can get belts for the flail mower from any retailer.
Just be sure to ask for a green kevlar belts as they have
better shock resistance.
All they need to do is measure the belt to get the correct one for you.
All V belts and bearings are metric and that makes it easy to take care of
Welcome to the Flail Mower Nation Jerry
Only 17,750+- mowers to go
_____________________________________________________________________________________________
Once you go flail you never go back :^)
Pronovost or not at all!!!
/ Bought this flail mower #11
Takes a banded belt, don't think they're available thru NAPA. Got mine from a tractor dealer, might have been McGees. Parts diagram calls for size B57, but I found that to be too long. Have a B53 on mine, but there's enough take-up in the idler adjust to use a B54 inna pinch. Having said that, I'm assuming all 917s use the same belt. Check your specific parts diagram to be sure
//greg//
/ Bought this flail mower #12
Looks like you have it figured out, but just wanted to add some info., albeit late.
Definitely 917 or 917A. If bracket for gearbox that bolts to frame is Z-shaped, then 917. If U-shaped, then 917A. Gearbox was used on 907, 917, 917A and 917H. 917L had a square gearbox. 917H has a welded back skirt instead of bolted.
Thanks TractorTech. I appreciate your feedback. Hopefully the old gal has a lot of productive hours left in her without a lot of maintenance issues.
