Let's see your Kubota
/ Let's see your Kubota #281
Very true, plus if no one is there to witness, you can make tell the story "better" when you tell how you got un stuck. Mine get "better" every time I tell them.
Always make the story better; never have a witness when you laugh at yourself. (says the woman who almost sunk into the slough)...:laughing:
/ Let's see your Kubota #282
My Kubota got to play in the snow today. Just made a nice path so we can leave the house.
/ Let's see your Kubota #283
I was totally awed by Piston's posts and the work he has done. I thought you all might get a laugh to see someone operating at the other end of the spectrum:
Last winter, I discovered I had about a half dozen lodgepole pines that were infected with beetles. In winter, the snow was too deep for me to cut them, so I waited until spring. Once I cut them, I limbed them and prepared the limbs for shredding, so they would not attract beetles. I then used a drawknife to skin the bark off the trees. This killed the beetles, so they could not spread to other trees.
I had a problem with black bears, and decided I needed a place to hide my trashcans. I decided to use the logs to build a small hut. I used my Stihl 026 chainsaw (about 30 years old, runs well, but a bit small) and an Alaska chainsaw attachment to cut two parallel faces on the skinned logs.
I used the faced logs to build a primitive log hut. The construction technique is similar to that used locally during the late 1800エs and early 1900's. True log cabin builders will readily curl their lips, as the techniques used were fast, simple, and less than elegant.
My house was built in 1948. It was sheathed with local pine boards. When we bought the house and remodeled in 2008, I saved the boards. I used some of them to line the inside of the hut.
Come spring, I have to chink the logs. It's too cold now to do cement work. I also need to add door hardware. The whole effort was fun, but a lot of work.
Love it... I want to do something like this.. Just need to find some spare time. Looks like a lot of fun though!
/ Let's see your Kubota #284
This photo could also be titled how not to backfill a trench. Got an old l3600 with a fel and a bh. So far she's cut the beginning of a road for the new house and dug 780' of 3' trench for electric.... She's old and shows it but compared to the john Deere 1530 I was using before she's a dream. Actually starts in the winter when there is snow on the ground. :)
/ Let's see your Kubota #285
Looks pretty capable to me.
/ Let's see your Kubota #290
Aaron, I would have thought about leaving that last picture off. Heck, I wouldn't have even taken the picture. But you have a good looking tractor.
Larro
/ Let's see your Kubota #291
Just a reminder to pay attention to your surroundings and always wear your seat belt.
/ Let's see your Kubota #292
Larro
I was going to say there are easier ways to empty a fuel tank than tipping the tractor on the side.
/ Let's see your Kubota #293
Well at least you were giving a good trial run. I have always been able to get my backhoes out of a bind by using the backhoe to raise and swing my back end to the side to get onto new ground. Or pulling myself out with the bucket. I try not to sink in by spinning the tires. Do you have R4s?
I've never seen a tractor with racing slicks before!!!:laughing:
/ Let's see your Kubota #294
Brr cold out today 12 degrees got out of school early went home got the battery charger and started my families 1983 kubota l235 moved snow for a while wishing for spring to come soon
In western mass
Kubota81
/ Let's see your Kubota #296
She can't get enough of it either.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=351275"/>
Wow that's a massive grapple!
Girls like tractors too! (0:
/ Let's see your Kubota #297
Here's my L4330 on the trailer.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=350623"/>
What brand trailer? I like it!
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2005 FRAC TANK 500BBL WHEELED (A63569)
2005 FRAC TANK...
2006 Chevrolet 3500 Flatbed Truck (A63116)
2006 Chevrolet...
Fair Oaks 10'  Multigrader Blade (A64047)
Fair Oaks 10'...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
