Woodmaxx 3 pt hitch Backhoe WM-8600 comments
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments
UPDATE:
Woodmaxx customer service is GREAT! They are very responsive and helpful with the issues I've experienced. Replacement parts are being shipped to include a longer top link to help with the lean-back issue. They have addressed my concerns and were receptive to suggestions for improvements in the assembly manual where needed. So far, I'm very satisfied with their responsiveness and happy I made the decision to purchase from them!
HP
Just to close this out, Woodmaxx sent a new hydraulic tank, along with a thumb pin and longer top link. I'm satisfied with their customer service and willingness to adjust any issues you have with your purchase. I would recommend the two pieces of equipment I've bought from Woodmaxx and they stand behind their products.
HP
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #13
HP
Hi HP
Thought I would check to see if you are still happy with your backhoe after a year or so. I am looking at buying the same unit in the next few weeks.
Thanks for your post. Great information.
MM
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #14
Glad to hear that the bh6000 really exists. I have been to two dealers about a month ago and I haven't heard back from them. They don't have sense enough to know that if I buy a tractor in the near future, I am hoping to, that I won't be buying there.
Hi HP
MM
I've used it here and there. Not near as much as I'd like to. I deployed last year and came home to a new job within our organization so it's been hectic for a while. I'm in the middle of converting it to a frame mount. I didn't like the 3pt setup because I was too worried about breaking the tractor. I bought an old left-over Kubota subframe for my tractor and have mounted on the tractor. I have a fabricator lined up to make the steel plates for the interface from the BH to the subframe. Just need a chance to make templates for the fabricator. I think it will be a strong digger once I complete this project.
HP
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #16
Did you ever get your subframe made for the backhoe? Just curious how it works and if you have any pics.
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #17
Normally, we these Chinese backhoe doesn't supply subframe. I have no idea if there is one sub frame can work on all the tractor.
Mark,
Its taken a while to get back to you, but the answer is I'm about 80% there. I purchased a subframe made for my Kubota. All that's left are two steel plates to connect the BH to the sub. I just can't seem to find enough time to get a template to a machine shop to fabricate the plates needed to hook to the Kubota sub. I know it will be much stronger once I finish this piece.
HP
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #19
Thanks. Would love to see pictures so when you're done!
   / Woodmaxx 3 pt hitch Backhoe WM-8600 comments #20
Mark,
HP
I know this has been a while, I'm just wondering how the woodmaxx equipment worked out? Specifically the backhoe attachment?
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
