Snow Original Cab with joystick control photos
   / Original Cab with joystick control photos #1
PeterK
Gold Member
Central Maine
Kubota BX24 TLB
Here's a couple of shots of my BX24 with OriginalCab hardtop cab with glass windshield. I built a joystick controller for the electric rotator (window motor) and deflector (12V linear actuator.)
In the photo you can see the joystick mounted in a plastic project box that I sprayed with bedliner. The box is attached with a liquid-tite nipple which also provides a conduit for the wiring. The 5x5 aluminum box on the left houses 4 automotive relays and all the wiring. This setup uses the joystick to switch ground to one of the four relay coils. Details if you're interested. btw - my old setup was two dpdt rocker switches. They worked fine but not at my finger tips and harder to press.
   / Original Cab with joystick control photos #2
Nice job on the joystick, I'll bet you can't wait to try that baby out.:thumbsup:
2014 International Derrick Digger Truck (A55973)
2014 International...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
