422 OIl Filter Removal
/ 422 OIl Filter Removal #1
Frank Sorbello
Gold Member
Power Trac PT-422
Is there an easy way to take off and on the oil filter. Can't get hand between tub and filter.
Thanks
Frank
/ 422 OIl Filter Removal #3
Frank, are you talking about the engine oil filter or the hydraulic oil filter?
/ 422 OIl Filter Removal #5
Not sure how you are doing it, but I move the gas tank out of the way and take the heat shield out. It's still a tight fit but I can get my skinny arms in there.
/ 422 OIl Filter Removal #6
I've gotten one of those plastic filter wrenches on to a swivel with extension on to a ratchet and was able to get it loose. I remember I think it was MR, said to get a baggy over the filter before it comes off, to keep the oil mess in the bag, so to speak.
/ 422 OIl Filter Removal #7
I've gotten one of those plastic filter end cap wrenches, like Kevin shows in his link, on to a swivel with extension on to a ratchet and was able to get it loose. I remember I think it was MR, said to get a baggy over the filter before it comes off, to keep the oil mess in the bag, so to speak.
/ 422 OIl Filter Removal #8
I use the baggy, but that's on the hydraulic filter, not the engine oil filter. My engine oil filter on the Kohler is very easy to access.
/ 422 OIl Filter Removal #9
12year old armed with a filter end-cap socket and ratchet, with supervision. or when I do the oil filter change myself I take the engine bolts loose and shift the motor to the side for easier access and remember to ''bag'' the filter to avoid the mess
/ 422 OIl Filter Removal #10
yeah, the bag is a good trick... sorry forgot to mention that. :)
/ 422 OIl Filter Removal #12
Remove the engine bolts, I'll have to try that next time and see how it works out for me.
I should have mentioned support the engine, mine always falls off the spacers that the engine sits on, better engine mounts should be in order
Changed oil today in my pt-422. Bought a wrench at Harbor Freight to take the filter that worked great. Plastic bags also worked great. Thanks for the tip. Now to the funny part. While putting the new filter on, I had both hands stuck between engine and the side of the tub for about ten minutes. It was difficult slipping them in there to spin the filter on, but I never imagined it would be so hard to get them back out.
/ 422 OIl Filter Removal #15
I swear that PT purposely cut the holes in the back of the tub just slightly smaller than the average mans forearms.
changing the filter is a painful experience. A nice 4" diameter hole in the bottom of the tub right underneath the oil filter would be nice. Or a remote filter kit.
/ 422 OIl Filter Removal #16
You could have the 1800 series. Filters are a breeze, but draining is a nightmare. The plug is easy enough but the thoughtful, insightful, brilliant engineers placed the hole for the oil to drain out about 1" too far back. My first few oil changes consisted of me filling the tub up, the waiting for it to drain out. Now I have an oil can cut up so that it directs the oil to the hole, but PT really is a PITA sometimes. Hmmm... I think we have the new company logo.
PiTa
Power i Trac a
s g
g
r
a
v
i
n
g
/ 422 OIl Filter Removal #17
I bought one of those finger-like wrenches from an auto supply place for the 4010 filter. No room around it for a normal filter wrench. I use an oil extractor to remove oil from everything now. Lots better than going underneath. I removed drain plugs and checked after. On the tractor, nary a drop came out of the drain plug after using the extractor. Only way to remove the oil from generators or other low down engines. Be really good for an inboard boat engine, too.
Ralph
Thanks Moss Road for the Subaru info. Some of those gadgets sure are neat. Power Trac should look into using some on the equipment on there right from the get go. Remote oil filter and drain extension sure would make an oil change quite easier.
CAT Flat Bottom High-Capacity Material Bucket (A64047)
CAT Flat Bottom...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
Caterpillar 302.5C Mini Excavator (A61572)
Caterpillar 302.5C...
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
